Question about Drills
My Milwaukee C 1418 C charger has no lights and doesn't charge when I connect the battery. Fuse F101 is okay and only 4V is coming out (18V output) Any ideas or am I just being stingy?
5 Suggested Answers
  • 708 Answers
SOURCE: Some Ryobi 18v batteries charge, others don't.
Had the same problem with some makita batteries, Was going to throw them away so decided to take apart and see what was happening. The are made up of 1.5 volt cells soldered together, found that many had .9 volts or less and others had 1.5 or more. This means that some of the cells had gone bad (probably due to lack of chemical reaction). Found that if I collected all of the 1.5 volt together could charge just fine. Problem is it is very hard to get them all soldered back together and even harder to enclose them. If a mfg. could come up with some way to change cells individually they could make a lot of money and save us a lot. So the answer to your question is buy you at least one more battery and recycle your old one.
Posted on Mar 28, 2009
  • 7 Answers
SOURCE: can i charge a 14v battery using a 18v charger (both are ryobi)
Absolutely not. The risk of damage to the battery is only a minor concern compared to the fire hazard you would be creating.
Posted on Jun 11, 2009
carlsbiz
  • 1124 Answers
SOURCE: light on ryobi 18v charger
More than likely a defective battery sinse the other ones charge fine..
Bring it back for exchange of another one..
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
Posted on Jul 31, 2009
  • 13 Answers
SOURCE: The Yellow and Green light both come on and stay
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more than 15 minutes it probably a defective battery pack. See page 8 in the manual.
Posted on Nov 24, 2009
Battery light comes on charge light will not dc out put 24v 4v charger prism GHC-244000il-EMI no output when could I have a problem other than charger has an 1605 inhibit boost
hi , what is the name of the mobility scooter please ? have you checked that there is no fuse fitted to the charger line ? can you please try another charger ?, this will eliminate the scooter ...
Regards
Rob
help me help you ...
Sep 21, 2015 | Health & Beauty
Milwaukee M18 18v lithium ion battery will not charge.
there is no fix for lithium ion batteries , JUST REPLACE
Dec 17, 2017 | MILWAUKEE ELECTRIC TOOL CORP 48-11-1828...
I have an 18v Milwaukee drill. Can I use a 28v charger to charge the 18v battery
Generally, When your have the 18V milwaukee drill, you had better to use the same voltage battery charger to charge the battery. it will be more safe.
John.
http://www.anybatteries.com.au/battery-model.php/Power-Tools-Battery_milwaukee.html
Mar 19, 2013 | Drills
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Feb 15, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Milwaukee 18v battery
No, it's showing that the battery is either not taking a full charge or the charger is not charging the battery properly. Find a Milwaukee service center, they will check them and most likely replace one or the other.
May 27, 2009 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
I have a milwaukee 18v cordless drill with litium battery packs why battery is not charging light blinking on battery for a while then charger light turns green as if it is charged full but is notcharged.
probably ur battery has memorize the charge u have to discharge completely the battery until there´s no power in it. so u can charge it again.. otherwise..change the batt!
Mar 10, 2009 | Tools & Hardware - Others
Dewalt batteries
There are typically two to three contacts on battery packs. One to charge the battery, one to 120v (household) ground, and in the case of the third contact, grounding the battery pack.
Jan 21, 2009 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Drills Logo
119 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
