Question about Sherwood Televison & Video
How to service/lubricate (and what with)the disc tray on a Sherwood CDC-5010R 5 disc multiplayer
After 25 years my above player gets sticky from day to day, so far I've got away with opening the tray and pressing the button that rotates the tray. Eventually the problem sorts itself out, I would like to do something about it before it siezes up completely.
  • Stephen Carey
    Stephen Carey Nov 23, 2014
    Quite, but I really need to know how to get at the relevant parts. Like most modern things the works are hidden, as are all the means of removing coverings. opening the machine up won't help either because inside the 5 disc tray remains intact in the machine.
    Top Expert:
  • Sherwood Master
  • 42,561 Answers
Try a small a squirt of silicon spray on the moving parts
Posted on Nov 23, 2014
Testimonial: "No moving parts directly accessable, covers deny access and offer no obvious means of removal or route thereto. Opening the machine will not help as the 5 disc tray remains intact withing the whole machine when closed."
worldvet
  • 859 Answers
SOURCE: DVD tray will not open.
The disc is dislodged and jamming the drawer. You have to remove the cover, about three, maybe four screws, and then take the disc out to resolve the problem.
Regards,
Worldvet
Posted on Jun 15, 2008
SOURCE: Conia M580 DVD player has
Easy... follow these instructions
  • unplug from the mains
  • take the cover off (3 screws on back panel, 1 screw each side, sticker on top front)
  • You will see the DVD disk in the player drive
  • Remove the plastic ******** top of the drive - 2 x small phillips screws
  • Lift out the DVD disk.... done.
Posted on Nov 30, 2008
Testimonial: "Many many thanks for your help - your instructions were dead-easy to follow and I've now successfully rescued my much-prized "Black Books" DVD disc!!!"
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
  • 3 Answers
Hi All
I had a similar problem with my fathers XBV342, my problem was that the DVD tray would open but when a disc was inserted it would close then open again time after time.
I took the top off of the unit and the front cover fascia panel off then checked the tray movement, I found that the belt for the tray motor located near the front of the tray was loose, which meant that the motor did not raise the drive motor to its correct location, which in turn didn't allow the motor to turn the disc, this causes the tray to open again, I guess it thinks it has a misaligned disc and ejects the tray, I hope this helps someone.
Posted on Jul 09, 2009
  • 56 Answers
SOURCE: Disc tray does not open...
completely reset the player, unplug the AC
cord from the AC outlet for 5-10 seconds
Posted on Mar 21, 2010
Only one speaker is working
Can you switch the wires to the speakers?
That will tell you right away if the problem is with the speaker or the output.
Oct 10, 2015 | Sherwood CDC-5506 - 5 DISC CD PLAYER SUP...
Sherwood CDC-5506 5-Disc CD Player - does it need Amp ?
Yes you need and amp Look at the disc player there is no volume control or speaker outputs.
Nov 21, 2013 | Audio Players & Recorders
SHERWOOD CDC-2000C ?D6376 starts skipping it was sent to be repair played about 2 discs when I got it back and started skipping again
Unfortunately the laser pickup assembly needs to be replaced, overtime the laser becomes weaker until it can not track properly and will end up skipping or won't read the disc. It is far cheaper to replace the CD player than have the assembly replaced.
Mar 19, 2011 | Sherwood Audio Players & Recorders
Does it only play dts, my sherwood cdc 5090r player. it cant seem to play mp3. can it play WAV?
Yes, wav is what a regular audio cd format is made up of. That is what i would burn if you want to listen to them on the player.
Thank you,
Lee
Jan 02, 2010 | Sherwood CDC-5090R 5-Disc CD Changer
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
Is there a way of connecting my ipod to my sherwood cd player?
The answer isn't with the CD player, it's with the amp.
Does the amp have selectable inputs, or does it just have one input for each channel?
If it's a simple power amp, then you'll have to unplug the CD player and connect your iPod to the amp inputs. I'm guessing that the CD player connects to the amp with RCA (phono) connectors like these ones.
If that's the case, you can get a cable (like this one at Radio Shack, but any office supply store will have one too) to connect your iPod to the amp.
Jul 31, 2009 | Sherwood CDC-5090R 5-Disc CD Changer
5-Disc CD player
your tray is out of track, have to place it back. not that easy but you can try. dont force it of you can damage the tray or gears
Nov 21, 2007 | Yamaha CDC-765 5-Disc CD Changer
My CD changer's disk tray keeps opening up, refuses to play discs
You have a problem with the try control circuit. It could be the switch is leaking across itself. Could be a problem with the tray motor control IC, or the Microprocessor is not reseting the open tray line correctly, or theres a cam assembly inside the unit that tells the microprocessor where everything is by means of small micro/leaf type switches thats out of alighnment or broken. If its seven years old, you got more then it was designed for and I would'nt invest a dime or the time into the repair of this unit. Time to take a trip to the electronics store. Good luck
Jul 21, 2006 | Yamaha CDC-755 5-Disc CD Changer
Televison & Video Logo
Top Sherwood Televison & Video Experts
Bill Boyd
Daryl Gleaton
Are you a Sherwood Televison and Video Expert? Answer questions, earn points and help others
