Question about Epson LX-350 9-Pin Serial Impact Dot Matrix Narrow Carriage Printer, 347 cps 10 cpi, Bi-directional Parallel IEEE-1284, USB 2.0, Serial
When i am trying to enter setting LX 350 it print only HEX DUMP
I need to change some settings when i am trying to enter setting by pressing LF/FF and LOAD / EJECT button. It prints only HEX DUMP these to words.
  • 36 Answers
Have you tried using the instructions from this page:
Using the Control Panel
Posted on Dec 19, 2014
Printer is ok but when i give the print command after some time it shows error which ''print error'' what is the problem
I'd like to have answers for some questions.
1) What interface do you use? Parallel or Serial
2) Does the printer run the self test? Switch on by holding LF/FF
3) Let me know the printer settings. You can find it by Switching on printer by holding FONT button. After it prints some data, press LF/FF. You will get the current settings of the printer.
Thank you!
Sabharish
Oct 13, 2009 | Epson LX-300 Matrix Printer
How to change boud rate from 19200 to 9600
Here are the complete steps to change your LX-300 bit rate to 9600.
1) Load a paper with the friction lever up.
2) Hold the FONT button and switch on the printer. The printer must sense the loaded paper and must start printing some stuff. If not it rolls and tries to load the paper. In such case insert the paper again and press PAUSE button. Now the printer will print the stuff i.e) the current printer settings.
3) After the printing finishes (the print matter will be around 25% of a 11inch page length), press LF/FF. You will find the current settings. Check the current bit rate which is indicated in the 10th line of the current settings table.
4) Now press LF/FF which takes you to the Table B.
5) Now you are in table B and the lights 1, 2 and pause must be Blinking, Off, Off conditions respectively.
6) Now press the FONT button 9 times. After pressing FONT nine times, Light 1 = Blinking : Light 2 : Blinking : Pause light : ON.
This means that you are in Bit rate menu now.
7) Press PAUSE button.
8) Note down this order of bit rate and the status of 1, 2 and Pause lights.
--300 = ON-OFF-OFF
--600 = OFF-ON-OFF
--1200 = ON-ON-OFF
--2400 = OFF-OFF-ON
--4800 = ON-OFF-ON
--9600 = OFF-ON-ON
--19200 = ON-ON-ON
From the current bit rate you are in now, press the FONT button a particular number of times accordingly.
Suppose you are in 1200 bit rate currently, the lights status will be ON-ON-OFF. If you want to set to 9600 you have to press FONT button 3 times and the lights status change to OFF-ON-ON , which indicates 9600 bit rate.
9) Now, press PAUSE button so that the settings get saved.
10) Switch off the printer and turn it back on after 20 seconds.
11) Switch it off again, Hold the FONT button and switch it in again.
12) After printing finishes, press LF/FF and check the bit rate in the current settings that is printed.
You can have the user manual for your reference.
files.support.epson.com/pdf/lx300_/lx300_u1.pdf
Thats' it. You're done!
regards,
Sabharish
Sep 30, 2009 | Epson LX-300 Matrix Printer
Serial port settings Epson LX-300+
Make sure you have at least 10 sheets of paper loaded.
Turn the printer off for at least 5 seconds, hold down the Tear-Off button, turn it back on, then release the button when the language menu starts printing.
After the language menu prints, verify the left and right Font light are off and the Pause light is on (for English). If not, press the LF/FF button until the lights are lit in this order. Press the Tear-Off button to select English.
Once the current settings print, press the Tear-Off button to enter setup. Follow the directions to change the serial port settings.
Mar 13, 2009 | Epson LX-300 Matrix Printer
Printer epson lx-300+II
Changing the default settings in the printer using the printers panel may be a bit difficult but it should be manageable. As soon as you enter the default setting mode it will print a guide, the guide will include the current setting. The guide will also give you the corresponding value of a certain setting according to the status of the light. The first two boxes will correspond to the font lights and the last box on the guide refers to the pause light. pressing the lf/ff button cycles through the options and pressing the tear off button will select the current option and cycle through the options as well.... However, in any printing environment, the setting in the APPLICATION OVERRIDES the setting in the PRINTER. So, whatever setting you select in the printers' default will be overridden by the applications' settings....
Jun 24, 2008 | Office Equipment & Supplies
Changing Pitch
use Epson remote utility to change any configuration
Mar 13, 2008 | Epson LX-300 Matrix Printer
PITCH Changing
you must enter in set up mode to printer,press the lf/ff buton and turn on the printer-that is the case in one type of setup firmare ,if you not enter in set up mode to try the same way with other buttons.in the set up printer print you the small guide,then you must foolw his until you reach a change pitch.
Mar 08, 2008 | Epson LX-300 Matrix Printer
Cannot restore the settings of printer like the tear of on the keybord... what did do to restore the settings of this printer... i cannot print  the print out is a symbol . same on the printest on the...
To do a Default Setting Mode to an Epson LX300+, you need to:
1. Power OFF the printer (for at least 10 seconds or more);
2. Press Tear Off button while simultaneously powering ON;
3. Release button, maintain power ON, printer will print basic/default settings.
At most times, it is the parallel/printer cable that gets dislodged. loosely connected or perhaps would even require replacement.
Should you want to do a printer self-test on an Epson LX300+:
Printer's Self-Test - The built-in self test function demonstrates that the printer is working properly. You can run the test with either continuous paper or single sheets; this describes the easier way, with single sheets.
* Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
* While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
* Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
* Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
* Press the PAUSE button. The printer begins printing the self test.
* To stop printing temporarily, press the PAUSE button.
* To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | Epson LX-300 Matrix Printer
DOT MATRIX PRINTER PROBLEM
Hi, to perform a self-test on an Epson LX300 > start with the power switch off. Press LF/FF (middle switch), without releasing that button, power on the printer. If everything is ok it will print a sel-test page. To do a Hex Dump > start at power off, simultaneously press Font and the LF/FF buttons (left & middle buttons), then power on; to revert the printer to its factory default setting(s) > start in off position, press Font (left) button then power on. (Slightly different with an LX300+) Hope this works out for you. Cheers.
Apr 19, 2007 | Epson LX-300 Matrix Printer
Epson LX-350 9-Pin Serial Impact Dot Matrix Narrow Carriage Printer, 347 cps 10 cpi, Bi-directional Parallel IEEE-1284, USB 2.0, Serial Logo
1,003 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
