Im only getting a black and white picture
Refer its user manual to get more details about its picture settings. Check whether proper color system has been selected.
SOURCE: Insignia 42" 1080p flat panel tv
you have lost your chroma (color) circuit the sepia you are seeing is just the black & white picture black and, white is adjustable from red to blue to green tint so; your sepia is an overloaded red circuit i could fix this but, i'm here and, you're there so take it to a serviceman it should not cost much more than $100
SOURCE: picture has shadowing or ghost like images
This unit is getting distortion form the video circuits, most likely capacitors or resistors causing distortion to the input or output circuits. This problem could be caused by a bad video amplifier also ,which is distorting the signal. This problem needs to be checked with an oscilloscope to follow the signal path and find the source of the distortion. Usually this is best handled by a service center. If the unit is still under warranty call this number for Insignia customer help : 1-877-467-4289. If the unit is not under warranty, you should take it to a service center and have an estimate of the problems and repair costs. You can find parts for this television at the Best Buy parts website. Just google it and put in the number of your television and it will list all available parts and prices. You can also call this number for Best Buy parts : 1-888-237-8289. Hope this helps you with your problem.
SOURCE: Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
