Change from 480i to 1080i
Model E390-B0
    Genius:
  • Computers & ... Master
  • 1,056 Answers
The KVM does not control the input signal it receives. It can only display what one device is transmitting and what the receiving device can display.
Posted on Nov 23, 2014
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Where do you go to to change the component-1 settings from 480i to 1080i on the menu?
That is done in the menu of the source. I.E.sat receiver,cable box, ect...
Dec 13, 2010 | Televison & Video
How to I change tv to 1080i from 480i?
this should automatically be done by the tv. If you input to a standard def input (ie yellow plug) or are using standard def cable it will be 480. If u change to a HD input or an HD channel it should automatically switch to 1080. The input displayed on the tv that says 480i or 1080i is just a result of what is being played, not a setting to be changed.
May 11, 2010 | Vizio VX37L Television
Want to change my cable box from 1080i to 480i
U can't not change mode at will,the 480i or 1080i is determin by the show what mode is play on.1080i only in HD,more HD will need to order from ur cable,dish or telicom compannies.
Dec 17, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Switch from 480i to 1080i
if the signal is not 1080i the tv will convert back to 480i. check your content.
Aug 20, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Sharp aquos 1080i is showing up at 480i. How do I
I have the same problem I'm sending 1080i to the screen and it will only display 480i. I too would love an answer to this question.
Jul 18, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Adjusting the resolution from 480i to 1080i
Typically TVs will auto adjust to the input signal it receives. If your cable box is only outputting 480i then all the tv will show is 480i. Ensure you have a good 1080i signal going in to the unit and check again
May 04, 2009 | Televison & Video
My ws-65611 always stay in 480i even with HD signal.
If you are using the component connection, make sure you are connected to the one that will support 1080i. If that is not the problem, make sure that the HD receiver is outputting 1080i and not 720p. No RPCRT will support 720p and the video may be down-rezed to 480 since this is the case.
Jan 25, 2009 | Mitsubishi WS-65611 65" Rear Projection...
NO HIGH DEFINITION
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    Computers & Internet Logo
    46 people viewed this question
    David Payne
    David Payne
