Question about Samsung Series 3 300E - 15.6" - Core i3 2350M - Windows 7 Home Premium 64-bit - 6 GB RAM - 750 GB HDD
Trouble shoot a sasmsung series3 notebook that had a short in the power port. Need possible area to check no power when switch is press to on.
I have removed the battery and tested the laptop charging terminals the meter showed power was geting to the battery i have no lights or power inication when turnd on.
  • 55 Answers
Sounds like the power supply circuitry has failed...... mains is stepped down to 12V for the battery... but the circuit includes Choke (inductor) and smoothing capacitors. I suggest you remove the hard disk and mount it in a caddy... so you can recover your data using the hard disk as an external drive.
Posted on Nov 25, 2014
What would cause the dash lights to come on when brake pedal is pushed down on a 1998 Saturn 4-door sedan?
A short somewhere or power back feeding through the circuit ! Do you know how to do electrical trouble shooting ? Find wiring diagrams for those circuits an see if they have anything in common , power supply , ground . test each circuit . This may involve taking your dash apart . Check the dash wiring harness for areas rubbed through an contacting other wires . You can find wiring diagrams at http://bbbind.com/free_tsb.html for free . Go to you tube an check out a few videos on basic automotive electrical trouble shooting , how to read wiring diagrams ,if your not familiar with them .
Feb 17, 2016 | Saturn Cars & Trucks
How to fix po1781 code on a 2001 dodge intrepid?
You will need automotive electrical experience to trouble shoot.
Hope this helps.
P1781 O/D Pressure Switch Sense Circuit Malfunction - With Automatic Transmission Possible Causes Setting Conditions • O/D pressure switch connector is damaged (check pins for damage, moisture) • O/D pressure switch is open, shorted to ground or shorted to voltage • O/D pressure switch has failed • TCM connector is damaged (check pins for damage, and for moisture) • Transmission relay connector is damaged (check pins for damage, moisture) • Transmission relay output circuit is open
May 13, 2015 | 2001 Dodge Intrepid
Model LG 42 PX3RVA ZC Hi I have a lg plasma, bought in 2005 new. I know it's old.. But was working well until a couple of weeks ago. Picture would flicker initially when turned on, then as tv "warmed...
With no stand by light, you are not getting power.Unplug TV and check fuse on power supply. You will need a meter to look for shorted components and possibly leaky/bulged capacitors that are killing your power supply. flickering could be part of the bad power supply or possibly a problem with YSustain area of your TV
Feb 15, 2014 | LG Televison & Video
2003 grand am no dash or rear lights fuses keep blowing mechanics cant figure out, tries tracing through driver door didnt work, go over bump it blows out,
Does your interior dome light work,if it doesnt take the dome lamp assembly out and disconnect the wire harness from there, reinstall the fuse and recheck lights,The possible short is coming from 2 likely areas the dome light or the dimmer light,what you do to the dome light to trouble shoot the short you will also perform on the dimmmer switch
Nov 12, 2012 | 2003 Pontiac Grand Am
My sony kp-65ws510 blinks a red light on standby
possible problem is on the G board which is the power supply suspect D6301 leaky causing this
there are also other possabilitys the D board there could be convergence circuit failure of hv circuit failure will need some trouble shooting to localize area of repairs needed
the amount of blinks once you have started it up do help to lead to a area for trouble shooting
Jun 05, 2011 | Televison & Video
I have a DV9720 US NOTEBOOK AND IT WILL NOT POWER UP - LIGHTS COME ON AND GO RIGHT BACK OFF...HELP.
If it only powers up for a moment, that sounds like a power issue. Is it plugged into the power socket? Also, is their a blue ring of light around the power port on the laptop.
Aug 21, 2009 | HP Pavilion dv9720us Notebook
Door ajar light and auto locks keep going on and off while drivin
It sounds like there is a short somewhere. Either a bad ground, pinched wire going from the door to the fuse box, or a possibly a bare wire shorting out onto something. You say that the door adjar light and the door locks are affected. Check the door switch and make sure that it isn't broken, shorted out or sticking. Function test it. If you disconnect the door switch and take a test drive does the problem still exists? Yes? Disconnect the other side. Did that cure the problem? Yes? Replace as necessary. No? The problem isn't in your door switch(s). So that much has been ruled out. These are just some areas to start trouble shooting. At first I immediately thought "Door Lock Switch," but when you mentioned that the Door Ajar light keeps going on along with the light then it leads me away from the Controls and more towards the Door light Switch usually in the jam of the door, but you didn't mention the year, make and model, so location of the switch is obscure. If the door locks are switching on and off and the door adjar light is in harmany with it then make sure the door is secure, not loose when closed allowing the door adjar switch to break the connection. These are the areas I would investigate first. Is there a significant amount of slop in the door when you push and pull on the door like it isn't secure? These are some areas to take into consideration when trouble shooting.
Good luck. I hope this helps narrow things down for you.
Apr 04, 2009 | 1999 Dodge Grand Caravan
No display on dv8320us PC notebook
It may not be your driver causing the problems, it sounds as though it might be your graphics card. Are you pressing Fn + F8 i think it is at the same time to switch between monitors? If that doesnt work, then i would consider replaceing graphics card (if possible)
Dec 21, 2008 | HP Pavilion dv8320us (HP RDV8320US) PC...
Dryer not starting
when u say u checked all areas for power did u use a muti meter.. ? to make SURE u had power?
u could try jumping out the door switch to check and see if the door switch is the problem
Oct 30, 2007 | Maytag HYE3657A Electric Dryer
Tv trouble shooting
1)Check secondary fuse devices. 2)Check horiz output xistor=shorted? 3)replace w/equiv.or better part. 4)Check solder connects in horiz drive circuit. Replace small electrolytic filter cap in base circuit of horiz o/p==horiz drive xformer and xistor area,typically 1mf/160v,C531? 2b)not shorted==do step 4 anyway 5)still blinking?==check vert o/p,audio o/p and regulated o/p's
Oct 02, 2007 | JVC AV-A21M3U 21" TV
Samsung Series 3 300E - 15.6" - Core i3 2350M - Windows 7 Home Premium 64-bit - 6 GB RAM - 750 GB HDD Logo
46 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
