Question about Dyson DC28 Animal Airmuscle Vacuum Cleaner
I would like to remove the clear cover over the brush bar on my Dyson DC-28 so that I can clean it. It's filthy and I cannot clean it with the brush bar in place. Is it possible to do this myself?
I started to take the brush bar out because it looks like it is removable but then I saw the belt cover and the belt holding it in place and it does not look like something I want to attempt without asking first to make sure I get the proper directions.
  • Official Brand Answer
  • 2,572 Answers
Hi there, it's Jack at Dyson.
DC28's cleaner head is a complex assembly which is not engineered to be dismantled. We'd advise against attempting this - any damage caused would not be covered under your Dyson warranty.
If you'd like some guidance on maintaining your DC28, please email askdysonUS@dyson.com and someone will be in touch as soon as possible.
Posted on Nov 27, 2014
  • Dyson Master
  • 18,387 Answers
It"s big job
Posted on Nov 23, 2014
  • 3 Answers
SOURCE: Dyson DC14 Brush Bar won't turn
You don't need to take it for repairs, I just corrected the same problem on the phone with a tech. Have the head on your lap, make sure the end nearest the little belt has the rounded side of the bar facing you. The squared off end faces towards the machine. Place your left hand pointy finger under the bar (the 2 inch bar next to the little belt) and lift up, while finessing the loose end of the bar into place, with the rounded part still facing you. Then it sort of snaps into place. Now, replace the face plate. In the upright mode, starting at the carpet dial, switch the dial back and forth between carpet and bare floor, ten times. (the tech actually referred to this as re-setting the vac. LOL) Plug the vac in, incline the hand, and start. It should work. It didn't for me the first time and made a horrible sound. That meant I had to go and repeat the process again, but lo and behold, IT WORKED! When in doubt, call the tech and don't let them get away from you; have them stay on the line until the problem is resolved.
Posted on Oct 10, 2009
SOURCE: DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Posted on Dec 23, 2008
geordie rob
  • 7 Answers
SOURCE: roller brush is not turning on a dyson DC14
http://www.dyson.co.uk/support/help.asp?product=DC07-SY&article=527
here's a link that might help
good luck
Posted on Dec 29, 2008
  • 389 Answers
SOURCE: Dyson DC 24 blockage between brush bar and
You can remove that short length of pipe very easily. Just pull it away from the fitting at the vacuum end and unscrew it from the brush bar end. While you've got it off, check it for splits (which are common) and replace it with a new one if it is damaged.
Posted on Jan 06, 2010
Testimonial: "Solved problem first time,also one we thought was a manufacturing fault,that side hose uremovable,were doing it wrong and this told us the right way."
SOURCE: How do I remove brush bar to clean the housing
area of trapezoid
Posted on Apr 17, 2010
Dc dyson 24 free repair maule
About 1,100 results (0.84 seconds) Search Results
    Dyson DC24 - Resetting the brush bar (Official Dyson video ...
    ? 1:55
    https://www.youtube.com/watch?v=akGLQ7UbctY
    Sep 29, 2011 - Uploaded by AskDyson
    DC24's brush bar is engineered to shut off for protection if something jams i. ... How to clear and reset the brush bar of yourDyson DC24 upright vacuum cleaner ... Dyson DC24: How toRepair a Loose and Clunky Ball. ... Dyson Ball DC 25 not locking beater bar brush in place while upright - Duration: 17:09 ...
    How to fix your Dyson Vacuum Cleaner when it loses ...
    ? 7:45
    https://www.youtube.com/watch?v=0vd3ldLXgI4
    Apr 16, 2013 - Uploaded by Chuck Fresh
    How to clean the two filters in your Dyson Ball or Animal Vacuum... troubleshooting computer problems, pc helpline, free pc repair... How to take apart Dyson DC 17 to Clean and Service - Duration: 14:33. n4ktz 178,332 views ... Dyson DC24 - Resetting the brush bar (Official Dyson video) - Duration: 1:55.
    [PDF]Dyson DC24 Manualhttps://www.dyson.co.uk/.../Dyson/.../Manuals/DC24_Manual.pdfDysonNote your serial number for future reference. After registering for your 5 year guarantee, your Dyson vacuum cleaner will be covered for parts and labour for.Dyson DC24 Manual - ManualOwl.comhttps://www.manualowl.com/p/Dyson/DC24/Manual/112339Manuals and user guide free PDF downloads for Dyson DC24. ... I Have A Dyson Dc17, Is There A Fuse Or Reset Button On The Vacuum Motor ... Complete Dyson customer service phone numbers and contact information at ContactHelp.com.Dyson DC24 Multi Floor Instruction pack - Part 914529-01 ...https://www.dyson.com/parts/u/user.../dc24userguide.aspx?...DC2...DysonDyson DC24 Multi Floor: Instruction pack - 914529-01.Buy genuine parts and accessories direct from Dyson.DYSON DC24 USER MANUAL Pdf Download. - ManualsLibwww.manualslib.com > ... > Vacuum Cleaner > Ball DC24Page 2: General Safety Precautions. Do not use with damaged cable or plug. If the supply cable is damaged, it must be replaced by Dyson Ltd, our service agent ...
Jan 28, 2016 | Dyson Vacuums
Dyson DC54 brush bar not rotating. Have removed all the hair, cleaned the brush and replaced, still not spinning.
Brushbar not turning Clutch check - Dyson
www.dyson.com/...dyson...not.../brushbar-not-turning-clutch-chec...
DysonBrushbar not turning - Clutch check. Please ensure that your hands are clear of the soleplate and brushbar before completing this test. Clutch check.
Resetting the brush bar (Official Dyson video) - YouTube
? 3:52
https://www.youtube.com/watch?v=AiKnefEr7ns
Jan 16, 2014 - Uploaded by AskDyson
How to clear and reset the brush bar of your Dyson DC41 Mk2, DC55, ... Dyson DC41 Mk2, DC55, DC65, DC66 - Resetting thebrush bar (Official Dyson video) .... Dyson Cinetic DC52, DC54with the Musclehead™ floor tool ...
Dyson DC44 - Remove & clean the Brush Bar - An owners ...
? 4:13
https://www.youtube.com/watch?v=_0a71p84sp8
Nov 12, 2012 - Uploaded by Tom Strong Reviews
Here is the fantastic Dyson Digital Slim Mk2 DC44 Animal. (DC45 in ... Europe) Here I show how to remove and clean the Brush Barof any tr... ... It is and easy operation and one you need to do whenever the brush is not clear.
Dyson DC54 Support - Turbine head not working properly
https://www.dyson.com.au/.../dc54/dc54...not.../turbine-head-not-workin...
Dyson DC54 Support - Turbine head not working properly. ... If you cannot clear an obstruction you may need to remove the brush bar. Use a coin to unlock the ...
Jan 24, 2016 | Dyson Vacuums
How to remove the brush bar cover
You can download the manual here: http://www.retrevo.com/support/Dyson-DC28-Animal-Vacuums-manual/id/23599ci662/t/2/
Here is the link to the Dyson DC28 support page: http://www.dyson.com/support/dc28/dc28-animal
Mar 05, 2015 | Dyson DC28 Animal Upright Vacuum New DC 28...
Why does my Dyson Dc-39 vacuum have good suction, but the beater bar barley turns?
The beater bar may be clogged with pet hair and other debris. You may have to do some disassembly to get everything working again.
Dec 18, 2014 | Dyson DC39 Animal Canister Vacuum
Brush bar will not release
Hi Lynda, it's Jack at Dyson.
DC28's brush bar is not designed to be removed by the user, and attempting to remove it could cause damage to the machine not covered under warranty.
If you're having any difficulty with your DC28, I would encourage you to get in touch with us directly so we can provide further advice. You can reach our experts by calling on 1-866-693-9766 (US) or 1-877-397-6622 (CA).
We'll look forward to speaking with you.
Sep 28, 2014 | Dyson DC28 Animal Upright Vacuum New DC 28...
How to get at beater bar belt on dyson dc 28?
DC28 includes a durable belt engineered to last the lifetime of the vacuum in normal use. It's part of the high-torque clutch mechanism, and we wouldn't recommend attempting to access or remove it as this could damage the machine. The belt is protected by a sensor which will shut off the brush bar for protection if something jams it, so it's very unlikely the belt itself would be at fault.
If the brush bar isn't rotating, the machine may need a simple reset. After checking the cleaner head for any obstructions, you should be able to reset the vacuum following the steps shown in our video guide:
If you continue to have difficulty after trying this, please contact our experts directly for further assistance. If a repair is needed, we can also confirm if this is covered under the 5-year Dyson warranty. You can reach us by calling 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jul 20, 2014 | Dyson DC28 Animal Upright Vacuum New DC 28...
Brush bar won't spin. Both filters have been cleaned ,all hoses checked for blockages,brush bar removed for cleaning
DC25 doesn't use a conventional, user-replaceable belt. Instead it it uses a belt engineered to last the lifetime of the vacuum in normal use, protected by a sensor which shuts off the brush bar if something jams it.
Normally, checking the cleaner head for obstructions and removing any threads or hair from the brush bar and endcap will allow you to reset your machine:
However if you've already followed each of the steps shown in our video guide without success, you may need a replacement cleaner head or a repair of your machine. If you can contact us directly we should be able to arrange this for you, and can also confirm if this is covered under your Dyson warranty.
When you have your DC25 easily to hand, please get in touch with the Dyson Customer Helpline so we can help determine if a repair or replacement part is needed. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Apr 06, 2014 | Dyson Dc 25 Animal
Also te red light is blinking on my dc 28 animal vacuum
Hi Judi, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC28. If the red on/off is flashing, this indicates that something may be jamming the brush bar. To resolve this, please follow the steps shown in the video attached. Make sure there are no obstructions in the cleaner head, and carefully remove any threads or hair from around the brush bar.
You may also want to try raising the brush bar one setting higher using the hight selector pad, as the brush bar will shut itself off if you have it set too low for the carpet pile you're cleaning.
If you'd like some further help after you've given this a try, please email us directly at askdysonUS@dyson.com with your contact details. One of our experts will be in touch as soon as possible to run you through some further troubleshooting.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Apr 17, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
Dyson Animal DC 28 brush bar removal
I'm sorry to hear you're having difficulty with your DC28's brush bar. I've attached our video which shows the correct way to remove any obstructions and reset the machine, in case this is useful to you.
The brush bar isn't designed to be removable, and attempting to remove it may void any guarantee on your machine. If you would like some further help it may be best if you contact us directly - our experts will be happy to confirm if we're able to repair your machine under the terms of our 5-year guarantee. You can reach us on 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Apr 05, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
Dyson DC28 Animal Airmuscle Vacuum Cleaner Logo
280 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
