Question about Sharp Televison & Video
I have a sharp television 14 inch. the problem is when i switch on the primary power switch the led turns red then pressing the secondary power the the led turns green then just about a second a click
I have a sharp television 14 inch. the problem is when i switch on the primary power switch the led turns red then pressing the secondary power the the led turns green then just about a second a clicking sound from the relays and the led turns back to red.
  • Sharp Master
  • 1,253 Answers
He's dead, Jim. Probably a bad capacitor or diode somewhere. If you can't repair electronics, it's probably not worth the repair bill.
Posted on Nov 26, 2014
    Sergeant:
  • 418 Answers
It is self-shutting down Something electrically bad inside. Could be anything. Usually some type of overload on power supply. Need training to troubleshoot.
Posted on Nov 23, 2014
  • 1694 Answers
SOURCE: power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Posted on Sep 26, 2007
charcois
  • 763 Answers
SOURCE: problem with pioneer elite pro-99
your tv's hardware might got the problem. this should fix with an expert technician that they have a tools for fixing this problem. if repairing will cost you alot then i suggest that you have to buy a new tv insted of repairing your old tv. hope that helps!
CHARCOIS
Posted on Aug 21, 2008
SOURCE: Power
same problem here
Posted on Sep 25, 2008
  • 108 Answers
SOURCE: sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
Posted on Jan 08, 2009
hbsurfdawg
  • 95 Answers
SOURCE: Won't turn on - relay clicks, power supply squeals, relay clicks, etc,
The television has a protection circuit. Sound like you know something about electronics so that is cool.
I suspect the HOT or High Voltage Transformer. If you want to operate on it, they typically will short externally from moisture or plastic high voltage breakdown. The TV starts, shorts as it cannot come to full high voltage, then shuts down. If your brave, you can unsolder the HOT which is the part that is on the main board or that comes from the top of the picture tube wire into a dark or spaceship type object.look underneath, sometimes they short underneath and you can scrap the carbon and get it to at least start up and work. Do not leave this as a fix as it can be a fire hazard.
The HOT is the most common. They are around 20-60 bucks. 34" TV. I am assuming this one without looking it up it is NOT a flat screen, as most do not squeal like that nor do they have to de-gausse like the old ones. I just looked it up and yes it is not a flat screen. Old school, so that is more thank likely the problem.
Posted on Mar 02, 2009
Sony trinitron 21 inch kv g21q1
It means that one of the secondary output voltages are short. You ll need to check every output voltage at the smps transformer. If the set is producing a hissing sound, then either the 115 v zeener is faculty or the horizontal output transistor is faulty
Jan 15, 2014 | Televison & Video
I have a Sharp model LC-42sb45u that will not turn on since power outage.
Voltages sometime increase/decrease during power outages. This mainly afftects the power supply of a lot of electronics equipment.
1. Check the fuse.
2. Check primary components like; Bridge rectifier, filter cap, switching components etc.
3. Check secondary (cold) side once you isolate the primary side to be ok.
Please consult a professional technician if you are not skilled in electronics repairing.
All the best
Rjn
Sep 20, 2011 | Sharp Televison & Video
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Washer won't start. Power is on, pressed power, then pressed permanent press, then water temp, then start. There is a red light on spin cycle and it just beeps and doesn't start.
Hi - if that red led light comes on as you press start - then the display module is faulty - however it's not always the case - often its the motor controller module thats faulty..
Your call - display module first and hope it works or controller.
The manufacturers recommended procedure is to replace the display module (primary) if it still doesnt work then replace the control module (secondary).
Cheers
Jun 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
My 20 inches sharp t.v has no power.at the secondary section has no voltage at all and the led indicator is off
Check for busted fuse inside your TV, so you can switch it back on. So, open it up. Follow the power cord going inside your TV. The fuse is just near to it. Have it replaced, and have it carefully clean free from dust using 1/2 inch paint brush. Put the case back close, and plug it back to your outlet. Switch it on. Hope this
Jun 03, 2011 | Kitchen Ranges
Key led is blinking
i have a 40 inch sharp tv an the red light keep blinking, the power light,it will come on with the gren light abount on for 1 minute then go off no picture.help
Jun 16, 2010 | Sharp VT-G14 14 in. TV/VCR Combo
Main power light turns on but i have no picture or sound
Take a closer look at the power board fuses. There is a fuse numbered 106 a little ways away from the rest of them. I have this same model and got it working long enough to diagnose a bad flyback transformer by replacing this fuse with one from Radio Shack. At some times, I could put in a new fuse and have the set work for a few weeks. The flyback transformer is available from parts.pioneerelectronics.com for around $60.
Jan 29, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
View timer only lights
TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
Dead KONKA 21 inch TV
try Check first all the output voltage in the secondary of the chopper transformer if regular voltage acquire. check secondary switching circuit feedback towards the opto isolator and syscon.
Assuming that HOT is OK.
Nov 01, 2007 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
