Question about Dynex ZRC-102 Remote Control 098TRASWANEDYA
How do I troubleshoot a Dynex ZRC_102 remote control
Have changed to new batteries, pushed all the buttons once
    Top Expert:
  • Dynex Master
  • 74,136 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Posted on Nov 23, 2014
Reprogram A DYNEX ZRC-102 Remote Control
If your Dynex remote can't control your Dynex TV, you need to try replacing batteries and testing operation. If no success, the remote or the sensor in the TV may have failed.
Aug 16, 2016 | Dynex Televison & Video
Set favorite
What do you want to know? Provide more details, please.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 24, 2014 | Dynex ZRC-400 Remote Control...
Please wait is stuck on screen.
Reboot.
Push and hold the power-on button for about 20 sec. The computer should shut down and allow you to restart.
Apr 13, 2013 | Dynex ZRC-102 Remote Control...
Program my insignia zrc-101 remote
Your Insignia remote already contains the codes. The instructions for your remote will tell you whether there is a code available for the device you want to control (TV, etc).
Dec 02, 2012 | Insignia New Original ZRC101 Remote...
I am trying to get the code numbers for Dynex tv
Unfortunately the user manual does not have a pre-programmed code for Dynex, so your best bet is going to be performing a code search.
To search:
1. Make sure the TV is on
2. Point the remote at the TV and hold down "CODE SEARCH" for at least 3 seconds, until the red light lights up solid
3. Press the "TV" button once and the light will blink once, then return solid red.
4. Press the On/Off button repeatedly until the TV turns off (go slowly enough that you don't keep pushing on/off after the TV turns off)
5. Once the TV turns off, press the ENTER button and the code will save (and the red light should go off)
This may take a while, so be patient, but if anything should get it working with your TV this will be your best bet.
Aug 25, 2011 | Innovage Jumbo Remote Control
I need the code the to my tv so i can program my zrc-102 remote to my dynex tv
Download this PDF for Dynex TV codes, look for the table of common codes, then simply copy it and enter it.
Jan 11, 2011 | Televison & Video
My dynex remote control for 32 inch flat screen stopped working, tried new batteries-no fix, any help? Can I use another or do I have to contact the company for a new remote?
I just called Dynex because I had the same problem. Remove the batteries and press the power button and hold it down for 15-20 seconds, put the batteries back in and try to power on and power off, change channels, etc... if so the remote is fine. The guy told me that sometimes when you need to replace the batteries you also have to re-set the remote control.
Jan 09, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
When I click chanel up or down the tv says please
For the Dynex ZRC-102 remote control channel switching.
1. Press the MENU button and select SETUP.
2. Go down the list and select FAVORITE CHANNEL MODE and switch it to OFF.
The +/- CHANNEL buttons will then switch channels when pressed.
Sep 28, 2009 | Televison & Video
My volume control on remote doesnt work its a dynex zrc-102 remote control how do i get a code or what do i need to do so i can ajust my volume from my remote control
Try the following first;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If you are still having problems, you should return the unit to the place of purchase for a replacement.
Mar 13, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex ZRC-102 Remote Control 098TRASWANEDYA Logo
159 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
