Question about Samsung 24 " Built-In Top Control Stainless Steel Dishwasher With Stainless Steel Tub - DW80F800UWS/AA
Se code Samsung DW80F800UWS What should I look For?
SE code Checked drain hose.Pulled unit out.What should do next
    Problem Solver:
  • 9 Answers
See my help tip. you need to clean the sensor in the bottom which will be covered with food gunk. simple to do and cost nothing
http://www.fixya.com/support/r25363284-fixing_5e_or_se_error_code_samsung_model
Posted on Jan 21, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 120 Answers
Theres a 5E I can't find a Se
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Posted on Nov 26, 2014
5 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: water discharge is very slow
Hi
This error code indicates a kinked or bent drain hose. A good indication that the drain hose is kinked and excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 07, 2011
SOURCE: i am recieving an SE
I'm getting the same message too. I turned it off for awhile and I had a technician come out and take a look. My drainage pipes are all clear (SE code can mean that drainage is not working properly). He suggested that I get a "Samsung" tech out to take a look at the circuit board/electrical issue. Want to know the crazy thing? This is my second dishwasher that Samsung replaced....all the same electrical issue.....and just last week someone called me to see if I wanted to buy an extended warranty on it. Hmmmm.....do they know that this a piece of junk? It was an expensive dishwasher too.....doesnt clean any better than my cheap model did and it sure has a lot more problems in this first year than the whole 5 years that I had my other dishwasher. Can you tell im disgruntled?
I would love to hear if there is a simple fix to this SE problem.
Posted on Oct 06, 2010
SOURCE: samsung dmt800rhs errorcode se
I had this issue; previous owners of our house installed new garbage disposal, but did not punch out the plastic stopper on the disposal where the drain hose connects.
Posted on Jul 24, 2012
SOURCE: SE error code on Samsung dishwasher
5E code. If your dishwasher has been running fine for awhile then throws a 5E code chances are it could be the pump or a blocked hose or filter but chances are its not. 1. Does the code come on after it has gone through the wash cycle and released the soap dispenser? or 2. Does the code show afer 1 or 10 minutes of running without the wash cycle completing, soap dispenser still closed?
Number 1 is easy to check just diconnect the drain hose and run the hose into a bucket to see if the hose or filter is clogged or pump is working. These machines only use about 2 gallons of water and the pressure is very low its easy to do in a bucket. If number 2 occurs, its not a clogged hose or filter or pump issue the machine is not even cycling.
If number 1 checks out ok you have water flow but shuts down and number 2 has occured, its your Case Level Sensor its the electronic solid state float, DD94-01006A its either sticking due to water impurities or its bad.
Its actually pretty easy to trouble shoot or fix. You have two choices but the machine has to come out. The sensor is located behind a metal plate on the lower left side ofthe machine. You can;t miss it it looks like a float, has a black float inside a clear plastic housing and some wires going to it. You can pull it out and clean it (The float should go up and down with no sticking at all). Or just buy a new one $35.00ish and put in. Also check the inlet hose to the float make sure its clear and clean DD67-0057A.
There is one catch to this that can cause lots of grief if ANY water at all comes out of the float while changing it. If any water gets in the bottom of the catch basin underneath, the very very sentive probes will detct it and throw a LE code and the washer will not work. that is not a big deal just need to pull the basin off and dry it out. The smallest amount of water can cause the sensors to react since its a protection system.
Samsung dishwashers are very quite and wash extremely well but there technology and engineering sucks along with their warrenty and repair manuals there are no manuals for the home owner or much for the repair guy.
That float will have problems again and again and again either its dirty or broken and will cause another 5E code situation.
Side note; food grinders in a dishasher are stupid! All dishes places in a dishwasher should be rinsed! A domestic dishwasher should not be used as a disposal. It makes your house stink and tons of bad bacteriea will grow in places you do not want it to, not to mention they are not made to work like you would think.
Best dishwasher with the least trouble, easy to fix, easy to dignose, easy to work on, good manuals, few problems, good warrenty, best built, quite running, washes great, very well engineered is BOSCH.
Terry
Posted on Dec 21, 2012
How to fix samsung dishwasher code se
The code is 5E
Apr 21, 2015 | Samsung Dishwashers
Samsung Dishwasher model DW80F800UWS with Error code 5E or "SE" error code.
The 5E error code on this Samsung dishwasher means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor. If this is Greek to you, then you should probably call a professional dishwasher repairman.
Jan 10, 2015 | Samsung Dishwashers
5e or se code on samsung dishwasher
The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose check out okay.
Sep 07, 2014 | Samsung Dishwashers
Se code
You're on the right track - SE error code on a Samsung dishwasher means "drain error". If you can get to it, try removing the drain pump. Chances are there is something in it that is blocking or impeding the impeller, or may be stuck at that end of the drain hose (where the check-valve is located.) Good luck!
Aug 01, 2014 | Samsung Dishwashers
SE display code on a Samsung Dishwasher
The SE (or actually 5E) error code means "drain error". Most often, this is caused by a blocked or clogged drain hose, or something hard getting inside the drain pump that is blocking or impeding the free operation of its impeller. If all that is okay, then you may have a bad ECS sensor.
Jun 17, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
What is an se errer code on a samsung dishwasher
SE (or 5E) means "Drain Error" or "water not draining". Check the drain pump and drain hose for any obstruction, of course, If okay, replace the ECS sensor.
May 19, 2014 | Samsung Dishwashers
What does samsung dishwasher error code se
SE (or 5E) on a Samsung DishWasher means Drain Error - Water not draining. Check the drain pump and drain hose for an obstruction; If that's okay, you will probably need to replace the ECS sensor.
Apr 21, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
I am recieving an SE code on my samsung dishwasher. I tried to reset the dishwasher by switching off the power to the machine for 20 minutes. still SE message
Sep 25, 2010 | Samsung 24 in. DB5710DT Stainless Steel...
What does SE mean ?
Hi, you need to drain the washing machine by removing the little door below the drum door and pull out the the hose with a white knob (beware alot of water comes out so have a couple of pans ready. the fault means that there may be a blockage in the debris filter (next to the outlet hose you just pulled out) am sure you have prob already discovered the fix by now though!
Take care
Jun 15, 2010 | Samsung WF203ANW Front Load Washer
I have the same SE error message on my Samsung dishwasher.
I got SE error on my Samsung. I need help how to solve this problem? Please help!
Jul 19, 2009 | Samsung 24 in. DB5710DT Stainless Steel...
Samsung 24 " Built-In Top Control Stainless Steel Dishwasher With Stainless Steel Tub - DW80F800UWS/AA Logo
388 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
