Question about Frigidaire 27 in. Electric Gallery Pro Series Self-Cleaning Double Wall Oven
I have a Frigidaire Gallery Refrigerator with bottom freezer that is only 3 yrs old. My problems are with the ice maker and the door seals. The ice maker in the top in the refrigerator makes ice but f
What can be done to correct these problems without coming out of my pocket being it's only 3 years old? Can you send a technician out to evaluate the problem without any charge to me?
  • Official Brand Answer
  • 2,267 Answers
Thank you for your post, Genie Byrd!
From my understanding your Frigidaire refrigerator is not sealing properly which is causing an issue with your icemaker. You may need to replace the component for your seal. I would recommend having a professional technician out to your home to properly diagnosis and repair your refrigerator. Are you under warranty? Typically, if you are under warranty a repair should not come out of your pocket. I would consult with your manufacturer for warranty coverage. Hope this information helps. -OOS
Posted on Nov 25, 2014
  • Genie Byrd
    Genie Byrd Nov 29, 2014
    How long after purchase does the warranty cover this problem. I have had the refrigerator approx 3 yrs.
4 Suggested Answers
  • 25 Answers
SOURCE: Last year, my 8 year old Whirlpool oven door would
Are you replacing the hinge guides as well? The hinge is usually only one half of the problem. When you remove the door, look into where the upper long arm of the hinge resided. You will see a little runner wheel. Touch it with a thin screw driver and see if the wheel feels loose. I'll bet at least one of them is!
Posted on Jun 25, 2009
heatman101
  • 43501 Answers
SOURCE: I own a Frigidaire Gallery refrigerator model #
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 09, 2011
machinetech7
  • 1344 Answers
SOURCE: how do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
Posted on Apr 25, 2012
Frigidaire double wall oven clean between the glass
Remove door off the hinges. Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire 27 in. Electric Gallery Pro...
Freezer thawed but red light never came on still runs.
Check out these tips that I wrote about that...it is a great place to start trouble shooting your unit...and something thatyou can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 25, 2011 | Frigidaire 30 in. Electric Gallery Series...
I have a frigidaire self cleanig oven and I want to clean it. I pushed the clean button and it lopcks the door but it does not get hot and act like it is cleaning. The oven is over 6 yrs old
These may be dumb questions... but do your bake and broil typically work correctly? What model do you have?
Depending on model, you should be able to press clean, high or low (2 or 3 hrs), then clean again. At that point the door should lock and the bake element should begin to get hot.
Aug 29, 2011 | Frigidaire Ovens
Frigidaire stove is about 12 yrs. old. My oven will not heat past 250 degrees and it takes along time to reach that temp. The stove never indicates that the preheat temp. is reached. This just started last...
Hello, welcome to FixYa.
If you can provide the complete model number (usually on inside of door frame or around the bottom door opening), I'll see what I can find for you.
There are many possible scenarios as I hope you can appreciate being this is a global repair site, even within' the Frigidaire brand so I'll need to clarify the make & model before moving forward.
Regards,
Macmarkus :)
Aug 14, 2011 | Ovens
I own a Frigidaire Gallery refrigerator model # frs24xgcw ,the freezer sidehas stopped cooling and there is an occasional buzzing noise. Refrigerator side is working.The refrigerator is approximately 11...
heatman101
Jan 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Have a 3 year old Wall oven and the racks don't fit properly anymore.Racks have either shrunk or the oven has gotten wider.
I have the CFES365EB2 Frigidaire slide-in model stove (3 yrs old) and I have the same problem. Did u get any answer ?
Dec 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is...
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
Nov 12, 2009 | GENJRS06 Electric Single Oven
Frigidaire 27 in. Electric Gallery Pro Series Self-Cleaning Double Wall Oven Logo
111 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
