Question about Horizon T92 - Treadmill
Horizon T91 Treadmill - Key Pad Troubleshooting
This all started when the displayed warning was LUBE BELT. Once I did, pressing the Stop button for 5 seconds did not reset the display and return the unit to working order. I noticed that the Stop Button did not beep. Here are the steps to verify proper function of the keypad. If some buttons beep but not others: Press the ^ Incline button and v Speed buttons at the same time. After a few seconds, ENg0 will appear on the display Press the Speed ^ and v buttons to get to Eng0 Press the Enter button Pressing any key will verify its function. A number will appear for each key pressed. If you press a key and no number is shown, the membrane keypad is bad.
    New Friend:
    Problem Solver:
  • 14 Answers
Correct. If the console is not responding or some buttons do but others don't the membrane needs replacement.
Posted on Apr 03, 2017
2 Suggested Answers
  • 12223 Answers
SOURCE: Incline - Button not working, and also Stop Button not pausing
RUN the software calibration INMEDIATELY, for diagnose, troubleshooting and fix it.
sincerely. God bless you
Posted on May 06, 2012
Horizon manual
once lubrication is complete, reset the console by pressing and holding STOP and SPEED + buttons for 5
Aug 02, 2014 | Precor Treadmill Belt/Deck/Lube Kit,...
Code 701 06 comes up
I have a T91 and first had the Lube Belt error. After lubing the belt and upon turning the unit on while holding the Stop (Not necessary according to instructions by horizon but I did it while powering up anyway) button down, the 701 06 was momentarily displayed. The unit then displayed the Lube Belt warning again. Lemme know if you hear anything, I am working on it.
Nov 17, 2013 | Horizon Exercise & Fitness
Horizon t207
follow this steps and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 08, 2013 | Horizon Exercise & Fitness
Horizon treadmill won't incline
Step 1:
see the diagram attached.
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
Error 5100. the ink cradle moves on start up, the ink cartridges are brand new. Won't print a thing... "Check Printer, Error 5100" Canon MX300. Used once.
You need to reset your printer to remove this error. But first, may I suggest that you remove first your ink cartridge. Clean the contact surface using a cotton bud moistened with alcohol. After cleaning return back the cartridge.
Follow these steps:
1. Turn off the printer
2. Press and hold down the Stop/Reset button and Power button for 5 seconds.
3. While holding the Power button, release the Stop/Reset button.
4. While still holding the Power button, press the Stop/Reset button twice
5. Release Power button (wait till you get the lights)
6. Press the Stop/Reset button 3 times each having a 3 seconds gap. (check whether you are getting the orange light or not)
7. Press the Power button and enter data.
8. Remove the cartridge. Leave it for 20 seconds
9. Press the Power button and shutdown printer.
10. Return cartridge and start the printer.
11. Set the language and country.
After the first reset procedure and there is still an error, do this 2nd reset.
When the error is displayed on the display panel of the printer, 1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button so printer will completely restart. After this, your printer will print again.
Please give this solution a 4 thumbs up rating.
Thank you for using Fixya
May 24, 2011 | Canon PIXMA MX300 All-in-One Printer
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
Dec 26, 2010 | Horizon T91 Treadmill
Not runing, i see lube belt
Temporarily suspend the message for five miles by holding the STOP key for five seconds.
Reset the console by pressing the STOP and SPEED "+" or "^" for five seconds.
If you need to purchase additional lubricant for your treadmill,call us 347 515 8670
Nov 24, 2010 | Horizon T91 Treadmill
How do I reset the computers timing belt information in a Toyota 2007 4.7L (VIN T, 5th digit, 2UZFE eng, 8 cyl) after making a timing belt change?
a) With ignition turned ON, using the trip switch (select/reset button) change the display to ODO, and turn the ignition OFF
b) While pressing the trip switch, turn the ignition switch ON and hold it for 5 seconds.
c) Release the trip switch, then press the switch again within 5 seconds.
d) The digital display should change to T-belt mode. The initial display "15" (0,000km) is displayed (ie. 150,000km).
While in the T-Belt mode, each press of the trip switch will change the displayed value by 10,000km increments. Once " 20 " (200,000km) is reached the display reverts back to " 1 " (10,000km) again. Remember, this setting is the number of kilometres to be travelled before the light comes on next, and once reset this counter will start from zero.
I believe the timing belt interval for all the 100 series engine variants is 150,000km, but this should be checked against each different markets servicing recommendation. This being the case, you shouldn't need to change from the default setting of "15".
Obviously for the US, the ODO is in miles, and I guess the T-Belt warning would be set in 10,000 mile intervals.
a) After setting the replacement setting value, hold the trip switch ON for more than 5 seconds then release the switch.
b) Check that the display has now changed back to ODO and that the warning light has gone off when the engine is started.
NOTE: If the T-Belt mode is completed, even though the belt replacement has not been performed, the T-Belt warning IS reset.
Oct 30, 2010 | Toyota Tundra Cars & Trucks
Horizon T92 - Treadmill Logo
763 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
