Question about Craftsman Garden
How to adjust front wheels toe in riding lawnmower
YTS3000 model 917 289241
  • Craftsman Master
  • 1,169 Answers
There is no adjustment. You can only replace bent and worn parts.
Posted on Nov 23, 2014
  • 6 Answers
SOURCE: Craftsman riding lawn mower wheel toe needs adjustment.
put it in reverse ton the wheel to the right and hit the wall again....or ir you were backing up when u hit the wall runn into foward
Posted on May 19, 2009
wadembly
  • 513 Answers
SOURCE: riding lawnmower older Craftsman 143406012 12hp searches for rpm/
the needle valve on carb is out of adjustment it should be turned all the way in & out 1-1/2 turns to 2 turns try that & let me know if i can further help ya
Posted on Jun 28, 2009
SOURCE: How do you remove the front wheel of a Troy Built
well depending how its fastened on there could be a couple different things to do. but no matter what take a jack and lift up the front. if its a c-ring get c-ring pliers and pull it off. then just slide it off. if it has a hexagon bolt take a socket or wrench take the bolt out and slide off the tire. hope this helps you
Posted on Jul 02, 2010
vincob
  • 718 Answers
SOURCE: I have a Craftman 19
There should be a long lever to your right when seated, move that lever forwards and backwards for height adjustment. Good Luck...
Posted on Aug 16, 2011
  • 11 Answers
SOURCE: craftsman model 536270211 13.5 hp ride on lawnmower won't start
check for water and debrie in float bowl and spark at plug
Posted on Jun 07, 2012
Ariens 42" lawntractor front wheels aren't straight
adjust the toe in -out and if they lean in at they top check bearings or king pin wear
toe in should be slightly in at the front(1/8 ") and wheels straight up and down
May 06, 2016 | Ariens 42 in 17.5 HP 6-speed Riding Lawn...
How to adjust toe-in on garden tractor
cant adjust unless the tie rod ends are adjustable
you have to replace link arms ,they are bent
Oct 21, 2015 | Craftsman Kohler Courage 26 hp 54" Garden...
My front wheels are toeing put I replaced the left spindle and that was out the problem what could it be
Toeing means toeing in or out at the front compared to the rear of the front tires To adjust this you loosen the lock nuts at the tie rod where the ends screw on and adjust it longer or shorter depending which way you toeing
May 24, 2015 | Garden
Undefinedright front tire out of line,l-130 riding lawn momer .right front
If the tie rod end has been changed, you will need to adjust the toe in by dropping the tie rod end from its connection to arm. Not the steering rod. Tighten or loosen the tie rod end on the steering rod until there is a slight toe in. Re install the tie rod end into the steering rod. If there is too much toe in, the wheels will spread when in reverse and steering is impossible. It may take several attempts to set the toe in properly. When proper adjustment is met, steering will be easier or as it should be.
Oct 16, 2014 | John Deere Garden
Craftsman yts3000 riding mower
Probably wheel will turn individually but try both at same time and they will probably not move. Am sending you diagram of tranny maybe it will help.
Oct 02, 2017 | Garden
John deere 145 toe in adjustment
Adjust by measuring between the wheels {metal rim} at the 9 and 3 o'clock positions. I.e, halfway point on the rim at the front and rear. You can measure between the tire, but it is more difficult to get a good, repeatable measurement. If it were an MTD, you could adjust the toe by bending the tie rod/ drag link.
tom
Dec 19, 2012 | John Deere 22HP VTwin 48" Riding Mower
How to fix the toe out problem on my 2010 craftsman lawnmower?
Your gonna have steering rods called tie rods going to each spindle (wheel). Most lawnmowers dont have threaded tie rod ends where you can unbolt it and turn it in or out to achieve perfect alighnment. If its a larger expensive tractor you will find this and its a easy fix but most likely you just have a bend in one of the tie rods or on some cheaper models there could be a plastic bushing warn out causeing play in the front end.( Being able to slightly turn wheels without steering wheel turning) I would most likely say you have a bent steering rod or two... GoodLuck Ken
Aug 04, 2012 | Craftsman Garden
My lawn tractor pulls to the right when driving can i fix this?
The Toe In/Toe Out will have to be adjusted (if the steering rods to each front wheel have sleeves), just like on a car.
Toe-in is the operating angle of front wheels on a riding tractor. If the front edge of the wheels point inward, towards each other, then the wheels have toe-in. If the front wheels point outward, the unit has toe-out (or negative toe-in). Adjustment of toe-in is necessary to maintain proper steering control.
Unlike automobiles, our tractors have pre-set camber and caster settings. Therefore no camber or caster adjustment is necessary.
Acceptable toe-in adjustment range for all of our lawn & garden tractors is anywhere between 1/16"-5/16". With 1/8" serving as the optimal range.
Detailed toe-in adjustment procedures for the various models of tractors are reviewed in the "Adjustments" section of the Operators Manual for the tractor.
If tires are not toed-in properly after adjustment, it is likely that other part(s) need service or adjustment. axles, wheel bushings, control arms and other steering components may be worn or damaged and will need inspection. Service these items as needed.
You haven't stated your make and model, so I can't send you the manual with the exact procedure for your machine.
Jun 12, 2011 | Garden
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
May 09, 2011 | 1995 Honda Accord
Adjusting front wheels
Grease the zerks with a general grease, tighten any loose points, check your wheel bushings. They might be worn, causing the wheels to camber or off-toe.
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
111 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
