Question about Sharp MX-2300N Color Copier
How do I fix the error code 'U2-30'on my Sharp MX 2300N color copier?
I have done Sim 14 and sim 88 sub 1,and the error code did not go.
Check that the EEPROM is properly set.
Check to confirm that the EEPROM which was
mounted on the PWB before replacement is mounted
on the new PWB.
Replace the MFP PWB.
Replace the PCU PWB.
Posted on Jan 06, 2015
    Sergeant:
    Champion:
  • 246 Answers
Please reset the machine by eject the power and data cable for a one minute and also re installer the printer driver
Posted on Nov 27, 2014
5 Suggested Answers
SOURCE: Help
Sorry bubbabear 64, you are wrong you need to reset the copier with sim 14, once you have cleared the jam, there is no sensor in the fuser so often if the paper gets crumpled in there is doesnt trigger and sensors so the customer trys to copy again and again, seen it many times.
John Sharp Tech
Posted on Jul 22, 2008
  • 24 Answers
SOURCE: Sharp MX-2300N Reset
Type in "p" "*" "C" " *" (that is p button, star button, p button, star button.) the machine will go into sim mode enter 14 then press execute which appears on the lcd and the yes to confirm, then press CA and the machine should turn off then back on again
Posted on Sep 12, 2008
  • 14 Answers
SOURCE: Sharp MX-2300N with error code H3-00. . how do I
Ensure you are in COPY mode
press # * C * ( one after the other, fairly quickly)
when the screen changes enter the number 14 on the keypad
press the B&W start button
press 1 for Yes when the question displays
press thw CA button
machine will re-boot and fault should clear. If it doesnt you need a service engineer. This is a fuser temperature fault
Posted on Mar 09, 2010
  • 11 Answers
SOURCE: MX-2300N Color Copier: I have a Sharp MX-2300N that has just suddenly sta...
yes open the front door remove the waste toner and you will see the 4 drum units each with a little green stick pointing out
pull this in and out a few times on each unit ...
hope this helps
Posted on Jul 13, 2010
CALL FOR SERVICE CODE H4-20
Possible causes for this are:
Thermistor defect
Heater lamp failure
Thermostat failure
Control PWB failure
Try the following remedies:
Check the heater lamp blinking with SIM 5- 2. When the lamp blinks normally:
Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light:
Check for disconnection of the heater lamp and thermostat.
Check the interlock switch.
Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
To enter self-diagnostics mode press the following # * C *
Feb 09, 2014 | Sharp AR-M237 Digital Copier
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
Error h4-00 code on AR- 5127. please what can i do to reset it. Thanks. It also says call for service even though the machine is new.
this error occures if:
The setup temperature (about 90°C) is not reached within the specified time (about 17sec) from turning on the power.
When the temperature of main heater lamp thermistor falls below 140°C in the standby mode or printing.
When the temperature of main heater lamp thermistor falls below 50°C in the pre-heat mode.
AS POSSIBLE CAUSE:
Main heater lamp thermistor defect
Main heater lamp failure
Main thermostat failure
Control PWB failure
Check the heater lamp blinking with SIM 52.
circuit.
If lamp lights and stays lit:
and thermostat.
Check the power circuit and the lamp
control circuit on MCU PWB.
SIM 14.
To clear, enter sim mode:
1) #/P key (program) ON ? Asterisk (*) key ON ? CLEAR key ON ?
Asterisk (*) key ON ? Ready for input of a main code of simulation
2) Entering a main code with the 14-key ? START key ON
3) Entering a sub code with the 0-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key
if clear with sim 14-0 doesn't helps, choose sim 52 to check the lamp, or call service!
Sep 13, 2011 | Office Equipment & Supplies
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
* Entering the simulation mode
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
Sep 07, 2010 | Sharp AL 800 Copier
My sharp Ar-m160 is showing E7 Sub-code 01 what should i do
Thats a Duplex model memory error, Use SIM 26-39 to make sure the memory capacity is 32MB if it isnt replace the MCU PWB with a suitable one.
To reset machine use SIM 14.
Aug 31, 2010 | Office Equipment & Supplies
Sharp ar-m236 error code H4-21
-H4-21 means: Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch.Check the power PWB and the MCU PWB lamp control circuit.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Sharp AR-M237 Digital Copier
I have error code h5-01 on my copier ar 275. how do i fix it?
Check for jam paper in the fusing section.
(paper winding, etc.)
Check fusing unit installation
Clear the trouble with SIM 14.
To clear the trouble with SIM 14, enter the SIMULATION mode.
Enter # INTERRUPT C INTERRUPT, then hit 14 and the START key. Then hit either OK or START again.
Exit the SIM mode easiest by turning the machine off and back on again.
Sep 25, 2009 | Sharp AR-275 Copier
Developer light and technician indicator were on
Hello sir; That's PM light, you may go to simulation 20, 21,and 26 to reset; Press"#" "interrupt" "c" "interrupt' then enter 20 press print enter 01 press print, to clear PM counter, now same procedure go to simulation21 and 26, on sim.21 sub code 1 set no PM at 1, on sim 26 sub code 36 set on 1. after all done press clear to exit.
Jul 24, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M237 Error Code H4-21
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Control PWB failure
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Type in 1 4
Press start
hit 1 for yes
hit start
If the error code recurrs ther are other problems.
Jun 05, 2008 | Sharp AR-M237 Digital Copier
Sharp AR-5127, the error code U2-40
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Apr 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp MX-2300N Color Copier Logo
509 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
