Question about Tascam Computers & Internet
I have an old Tascam 788 Portastudio. When I try to burn a CD or backup data I get the message "IN PANIC" What can I do?
I have deleted unused and re-booted multiple times
2 Suggested Answers
  • 189 Answers
SOURCE: Tascam 788
Sorry to hear about your problem. A number of things could cause this error to appear including bad sectors on the hard drive (which will require a reformat).
Two things you can check though before getting into replacing or reformatting the drive (which will erase all of your data) are 1) Make sure the power adapter hasn't failed. A bad or incompatible adapter won't provide enough power to the drive when it tries to spin up and could cause this error. You can try a replacement after-market adapter but you'll have to match the specs in the manual. 2) You can open up the 788 and inspect the two wires connecting the disk drive to the motherboard. One is power and the other will be an IDE ribbon cable. If either is loose that could be the cause of your problem.
If you do determine that the drive is bad you'll need to remove the drive, hook it up to a PC and reformat it there. Then reinstall it in the 788 which will upon bootup automatically reformat it again with Tascam's proprietary disk format. You can optionally replace the drive. I believe Tascam's site has a list of drives which are compatible with the 788. Reformatting (or replacing) the drive will obviously cause all of your data to be lost, but should get your 788 working again (if a bad format was the problem).
One thing of note if the drive format being bad turns out to be the problem is that Firmware versions 1.07 and below have a bug which can cause bad sectors to corrupt the drive after delete operations. If you have a firmware version which is 1.07 or below you should upgrade to a newer revision or you'll risk corrupting the drive again in the future. You can get the upgrade and instructions on how to apply it here: http://www.tascam.com/products/788;9,16,132,19.html
Best of luck and hopefully it's just a loose connection or a bad power adapter.
bd.
Posted on Nov 12, 2008
When I try to burn a CD on my TASCAM 788 Portastudio I get message "IN PANIC" at the very end of the process. What can I do?
If it's coming from where I think it is, not much... In Linux OS (which is free), when it's kernel crashes, it advises the user by "Kernel Panic". Usually these devices are built on a free software base, then whatever routines are needed to support the 'non-standard' hardware on the platform.
Bottom line is that there is either a hardware/software problem. I suggest you find out who makes the device and see if you can get help from them (via the web, "http://tascam.com/product/788/"). The only other approach is to start changing out hardware. You could start with the CD that you are using. Just try to get a 'like' device, which responds to the command that it uses. You can get it's model number and search for replacements.
I don't know what kind of help you will get, since the page at tascam stated it "has been discontinued". It is still a good starting place. With just the product, I found a list of items, such as FAQs and PDF files for it or like items. Might try and find one of these that has the word "panic" in it.
Best of luck.
Jack
Nov 24, 2014 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Mar 08, 2008 | Tascam 2488 Portastudio Multitrack...
On your computer??? what are you trying to burn on it? a system img?
Nov 22, 2014 | Audio Players & Recorders
How to download from the Tascam 788 to the CD Burner?
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Chapter 8
Feb 04, 2011 | Tascam 2488 Portastudio Multitrack...
Want to copy files from Tascam 788 to IMAC's Garage Band
The problem is thus. You have a multitrack recording saved in a format that your portastudio recognizes and you want to use it on your imac. If you can copy the file to the imac as a file, a translator, if one is available, will make it usable by the mac. You won't be able to play it and record on the imac because maintaining the recording as multitrack would require one output from the portastudio and one input on the imac for each recorded track.
Bummer dude. The kluge method would be to play/record 2 tracks at a time (or however many outputs and inputs are available) and hope for some semblance of time alignment, after which you can fine tune it and then start your editing.
Apr 09, 2009 | Tascam Electronics - Others
Tascam 788
bd.
Nov 12, 2008 | Tascam (cd-rw788) Burner
Tascam 788
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
Oct 20, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam dp01 fx cd.. OOPS!!! Please help.
Depending on the voltage that your laptop uses, if that voltage exceeds the Tascam required voltage you might have burned out the Tascam power board. Not good. I know you don't want to replace the entire unit. Try contacting Tascam directly they might give your an alternative in just replacing the power assembly.
Sep 20, 2008 | Tascam DP01 All-In-One Recording Package...
Tech support
http://www.tascam.com/i-874-232-128-0-540B4588.pdf
Mar 04, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Computers & Internet Logo
54 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
