Question about Specialized Demo 7 I
How do i remove the rear wheel of a Specialized demo 7 2008? it does not have a quickrealease handle!
    Master:
  • 706 Answers
Without a quick release, you'll need a 15 mm wrench. This operation is easy to take a part but can be difficult to reassemble. If you're not good mechanically, I suggest taking your bike to the nearest bike shop.
Posted on Nov 24, 2014
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: got a 2007 specialized demo
Chains don't just snap. Resolve the jamming and you'll have more success.
Shifting adjustment and controleld operator input will prolong the life of your drivetrain.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://www.sheldonbrown.com/chains.html
http://www.sheldonbrown.com/chain-life.html
http://www.sheldonbrown.com/derailer-adjustment.html
Posted on Mar 12, 2011
al_kupchella
  • 843 Answers
SOURCE: What is the proper tool to remove rear wheel
You need a freewheel/cassette removal tool. Here's a link to Park Tools page (great quality tools at reasonable prices) http://www.parktool.com/category/freewheel-cassette There are several different types to fit different styles. My usual method is to remove the quick release skewer, place the tool on the freewheel/cassette, put the skewer back on to hold the tool in place (skewer should be just a little loose). Put the tool side of the wheel down and clamp it in a vise. Then grab the wheel with your hands and twist it sharply (not slow and steady) counter-clockwise. Good luck, Vote if you found this helpful. Al K
Posted on Jun 08, 2011
How to install brake pads on specialized demo 8
Depends what type of brakes they are?
Jan 05, 2014 | Specialized Cycling
How to release front brakes
There is a brake release lever either on the brakes themselves or on the brake handle. It will be the only thing that you can move without a tool besides the brake operating handle itself. If you can't find it, you can always deflate the tire. One other thought-- it is possible that the brakes were adjusted with the brake release lever in the wrong position. If that is the case, when you move the brake release lever you will tighten rather than loosen the brakes. Good luck
Dec 21, 2012 | Specialized Sirrus
How to change rear wheel bmw scarver
Hi Anonymous, I am sorry you can't find the first and best tool you ever bought for your BMW but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
BMW F800GS Remove and install rear wheel
Technical Demo on BMW F650 Rear Wheel Removal
2001 2005 BMW F650CS Service Manual Moto Data Project
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 01, 2012 | 2002 BMW F 650 CS Scarver
Can't get rear wheel off to fix flat
Web search "remove rear wheel"
Aug 22, 2011 | Specialized Globe
What is the proper tool to remove rear wheel cassette from specialized CrossTrail to replace a spoke?
Jun 08, 2011 | Specialized CrossTrail
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
I have a 2007 Specialized s works roubaix. I have a ''clicking sound under load only that ''seems'' to be coming from the crank because it clicks at every rotation of the crank. the bike has about 3500...
I can tell you by my own experience that the click at every rotation is because the bearings on the BB, I had the same in my bicycle and after install a new crankset and BB it went away. I installed a Shimano Deore Hollowtech II and it works nicely and no noise.
May 18, 2010 | Specialized Bicycle Components Specialized...
Easiest way to change a spring on the rear shock on 06 demo 8
The easy way is the only way, you have to remove the shock from the frame, unscrew the spring and its perch should slide over the shaft at the rebound knob end (red knob). Be careful not to nick or scratch that shaft on the way in or out!! Put everything back together, screw the spring down so that the perch (support plate) has it's little slot in top of the red knob and the last bit of the coil (the part that is cut) is on the other side of the perch. Torque it down to 120in/lbs and go a ride!
Oct 07, 2009 | Specialized Bicycle Components Specialized...
Have to replace rear wheel bearings on 1987 sierra half ton
Not extremely hard just need the right tools for it and a manual.
Aug 12, 2008 | GMC Sierra Cars & Trucks
Specialized Demo 7 I Logo
127 people viewed this question
Top Specialized Cycling Experts
richie46
dante
Donald Ayers-Marsh
Are you a Specialized Cycling Expert? Answer questions, earn points and help others
