Question about Sharp Office Equipment & Supplies
Sharp AR5320E PROBLEM IS PAPER ALWAYS JAM
PAPERS JAM ALWAYS
  • 52 Answers
Clean the pickup rollers , if problem persist check the clutch
Posted on Nov 23, 2014
Bubbabear64
  • 2794 Answers
SOURCE: Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Posted on Jun 12, 2008
  • 169 Answers
SOURCE: Paper Jam/Stall - no paper jam
Well what you need to do is do a rest on the printer.That should solve the problem.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
sys_admin
  • 829 Answers
SOURCE: the printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Dec 30, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
rezazadeh
  • 328 Answers
SOURCE: SHARP AR5516 PAPER JAM ERROR MESSAGE
when you open side door in the up you see a black unit check if sesor not broken. also open cassete and see inside no paper jam there
Posted on May 29, 2010
Hp 1320 don't stop printing
my hp printer 1320 always prints two papers one of them is white.
what caused this problem?
Nov 02, 2012 | HP LaserJet 1320 Printer
It always experiences the paper jam.The papers always get stuck in the machine.
Please try to print 1 or 2 page dont give print above 2 pages otherwise it will get jam, and check the ink jet... if not printed please get back to me or you can send me mail. my mail id is varun.jeewa@gmail.com
Feb 09, 2011 | Office Equipment & Supplies
Laser printer manual feed jam
like the name goes, it is manual. You will have to feed the papers one after the other. if you do not want that, then load the papers into the automatic tray if you have one.
Incase none of the above works it means the roller that is suppose to pick the papers finds it hard to pass papers on to the other which you will have to replace.
good luck
Jul 04, 2010 | Samsung ML 1450 Laser Printer
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Started with a paper jam...now two parts popped out...
DEAR FRIEND
never pull stuck papers from front, always from back side
well what u have done is misaligned the clips movement
you cannot do it by urself,
u need a technician if it is out of warranty
if it is in warranty hp people will gladly take in for rma
thanks
Apr 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Printer problem
Hey there.
1-st of all please tell us what printer model do you have and what kind of paper are you using.
Mar 19, 2008 | Office Equipment & Supplies
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
