Question about Car Audio & Video
Looking for navigation and manual for a Vigo vch3206 navigation satellite radio The screen is black as application platform.exe if somebody tell me how to get into the radio so I can get the air remov
I try to hard reset pushing and holding all the buttons for a long period of time to try to reset all I have is volume and took and tune nothing comes on the screen The radio is a VIGO navigation satellite DVD CD or CDr
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
Shuttle83
  • 1139 Answers
SOURCE: Jensen VM9511TS AM/FM/CD/DVD/SD
you may have to open the unit up and manually turn the unload and load gear to eject the DVD from the carriage. The load and unload gear is a round gear located under the DVD carriage and is attached to the load and unload motor
Posted on Sep 21, 2007
hogan doan
  • 227 Answers
SOURCE: Volume Button on steering wheel not responsive!
There is a metal dome under each button, some time they became warped or inverted and you don't get the actuating contact on the first push but if you keep on pressing it eventually contact will be made and whoalaa actuation happened. If you are technical incline you can replace it with a dome of similar size of a device you no longer have use for, like a remote control, an old car stereo or telephone...ect. Goodluck.
Posted on Mar 05, 2008
jackboy
  • 2985 Answers
SOURCE: Can't get sound through car speakers/radio
I there is a DVD in the system and the machine us still saying no disc- try several different standard disks- it may not- like 'burned computer type disks'
If ttill in trouble assume the unit is faulty.
Posted on Mar 17, 2008
  • 5 Answers
SOURCE: No Function Screen or Graphics
you need to check the cable from the brain unit to the display unit. If you need to order a new cable. www,pacparts.com. Login as user with out any input. and look up your model number. probably going to be the rgb cable which looks to be around $80
Posted on Jul 12, 2008
How do you clear application platform.exe error code
Run a registry cleaner, such as Clean Genius.
Nov 17, 2014 | Car Audio & Video
Mio c520
You need to hook up your unit to your PC, via USB, then navigate to the Uniden website and download the Upgrade, the system software for your GPS, this will then allow correct operation.
http://www.uniden.com/pdf/GPS402om.pdf
It tells you what to do and how to do it in this owners manual above.
May 21, 2010 | Uniden GPS402 GPS Receiver
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
Can somebody please tell me what fuse number for radio
There are 4 fuses to the radio in the interior fuse panel.
no.22 (10 amp)
no.7 (7.5amp)
no.31 (25amp)
no.4 (15amp)
Apr 17, 2009 | 2005 Lincoln Navigator
I have a Toshiba 300. When I start up I get a black screen.
on the black screen, hit the ctrl, alt and del keys all at the same time, choose the applications tab, then click on the new task button. in the box type "explorer.exe" without the "
Mar 10, 2009 | Toshiba Satellite Pro L300 Notebook
Windows will not start
start your system in safe mode...
and run the scan pressing instant scan...
Here is the link
Apr 05, 2008 | Toshiba Satellite A15-S127 Notebook
Intellinav.exe application error
HELP!! I keep getting Fatal Application Error. Application entellinav.exe has performed an illegal operation and will be shut down. If this problem persists, contact the program vendor. Program: Intellinav.exe
Exception: OxC0000005
Address: 00125D64
Oct 11, 2007 | Nextar Q3 GPS Receiver
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
