Condensation not coming out of the unit
Nothing
    Master:
  • 571 Answers
Check the refrigerant charge...it may be cooling, but not cooling enough. More than likely, low on charge.
Posted on Nov 23, 2014
I have a rth6350d it worked fine until today when i change it from ac to heat now it runs for a sec and then the auxillary heat comes on under the number and i get nothing.
seems like the reversing valve cut out the condensing unit. it may be shorted. if not, something else shorted. did you check the main power fuses? if condenser is cut out it will go into resistive heat.
Nov 28, 2013 | Heating & Cooling
Burner time reset.
Are you sure you have an NR71? or is it an NRC model? only NRC models should be getting that code. Anyways, your house water treatment system has nothing to do with the neutralizer. The Neutralizer that it is telling you to replace is not there to treat the water going to your house. It is neutralizing the acidic condensate produced by the exhaust in your "condensing" unit. Without a new Neutralizer the condensate that drains out the bottom of the unit will be strong enough to kill plants and eat away very slowly at some items or metals underneath the skinny condensate drain. It's not a big deal unless you have the unit sitting above something you really care about and there's no condensate drain pipe attached. Either way, if you buy a new Neutralizer it comes with instructions on how to reset the timer so that you don't have to have the EC 92 bug you anymore.
Nov 14, 2013 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Does the orifice, which needs to be installed in the inside unit of an a/c for a house, come with the outside condenser? I had an a/c system installed and an orifice was never installed. the original...
The orifice is the metering device inside the evaporator coil and comes installed from the factory in the coil itself. Some condensers do come with orifices taped to the side of the unit, but they only do that to ensure you have the right size orifice. Sometimes you will have a 3 ton evaporator and a 2.5 ton condenser. In this case you want to change the orifice so that it meters the refrigerant correctly. But if you have a 3 ton condenser and a 3 ton coil, which is normal, you don't have to do anything. So to answer your question, your coil already came with a orifice inside and nothing needs to be done unless there are two different sized units as described above. Hope I didn't bore you too much and helped you with your question!
Aug 19, 2010 | Goodman CKL60AR60 Air Conditioner
Our Carrier central air is unresponsive, nothing at all, no noises, air handler and condenser unit will not turn on, please help me before I lose more weight in my 150 degree attic. The serial # for the...
I think you need to slow down and start fresh.
1) You have 115v at Transformer-You are reading from Red to White
on windings?
2) If that checked out OK are you reading 24v out of Transformer?
3) If yes, remove thermostat wires and put a jumper wire between
R and G. Put the Blower Door Back ON and turn on power
hopefully your fan will come on.
4) If the fan comes on, move the jumper between R and Y, put the
blower door back on and turn on power, indoor fan should come
on as well as the outdoor unit. If the happens you have a problem
with the low voltage wire being broke or a defective thermostat.
5) If none of the above happens and you do not have 24v Between
R and Y or R and G, but you have 24v on the secondary side
of the transformer, you have a defective control board.
Jul 20, 2010 | Heating & Cooling
I have Honeywell programmable eletronic thermostat model RTH230B. Tried turning on central air but the air conditionaing unit does not turn on. I then set the thermostat to the manual mode and set the...
This problem is more than likely not the thermostat at all. The best way to see if the thermostat is at fault, is to pull the cover off and you should see a R(Red) terminal and a Y(Yellow) terminal, carefully jumper the two wires together and see if the outside unit comes on. If not, then the problem doesn't lay in the thermostat. You can also jumper the R and G terminals and see if the fan blower motor on the indoor unit comes on if you don't have another person to help. The thermostat is just a switch board for your controls on the inside unit and outside condensing unit. It is all 24v wiring coming from the unit and supplying the power to the correct terminals on the thermostat. Unfortunately, if your problem is not the thermostat, you can have a number of different problems going on. A few places to look.....
1. Breaker box to make sure nothing has tripped.
2. Make sure your indoor unit is still coming on.
3. Outside disconnect box. It will be by the condenser and should have fuses in it (some do not). To check, you will need to ohm the fuses. IMPORTANT: If fuses are blown, you could have a short in the condensing unit which should be checked first before changing fuses.
Hope this helps some and good luck!
Jul 05, 2010 | Honeywell Programmable Thermostat Heater
I have a condensing unit not coming on when called. I didn't take the inside model numbers. here are the condensers numbers PUG24AYB what service manual do I need? Jeff
looks like a 2 ton condensing unit as far as manuals I don't understand what manuals you are asking about. If the unit isn't coming on when called for I would start by checking the 24 voltage side of the contactor to see if you are getting the required 24 volt. If you are I suggest checking the contactor to see if the proper voltage is coming out of the contactor. if so then move forward to the capacitor to see if it is working fine. If so then the compressor will need to be checked. But since nothing is coming on when you call for it there is a voltage problem somewhere so I would start there and work my way forward
Good luck hope this helped
Dave
Jan 29, 2010 | Heating & Cooling
Why does my fan runs continus. and the condenser won't run out side.
The fan runs continously because your condensor is not kicking on and removing the heat. The thermostat needs to come under the set temp. to kick off the fan. If your compressor doesn't run and the fan on the outside unit does run, your compressor has an issue. If nothing runs outside, then your transformer on the inside unit(air handler) has an issue. This could also be a control relay on the condenser or the air handler.
Jan 15, 2010 | Omega Trane Furnace Draft Inducer Blower...
PC comes on but it does nothing. No beep and nothing on my screen
Check if there are any blown or leaking condensators on the board. It is a very common problem and easy to fix for someone with some skills. If you do not find anything most probably is some microcircuit defective and it is not worth it to investigate more.
Oct 06, 2009 | Computers & Internet
Water overflowing from filter duck
It sounds like your condensation pan or your condensation hose is pluged up. I would first check the hose, there should be a hose coming off the unit and going to a floor drain. Pull the hose off and make sure it is clear of foreign matter (don't blow on it with your mouth, take it outside and use a garden hose or air compressor to blow it out). If there is nothing plugging that up then you may need to clean out your condensation pan which is located inside the unit right behind where you took the hose off. You may have to take some screws out to get to it once you you get to it make sure it is all cleared out. Also check and make sure your filter is cleaned and the coil is clean. The coil is right above the condensation pan. This should take care of the problem. ;-)
Aug 12, 2009 | Amana Heating & Cooling
What part do we replace first?
Door safety switch. You are sure you have power to furnace? jump out the G and R terminals on the furnace control board or turn your thermostat to Fan On to check. Make sure the door safety switch is in the closed position. Fan should come on. No fan, no power to unit. Check Emergency switch, circuit breaker and there may be a fuseable link in the wiring somewhere either above the unit or a condensate safety switch. Get power to the unit. Also check to see if there is a small fuse in the wiring inside the furnace or on the circuit board.
Jan 22, 2008 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
