My Whirlpool WTW7300 top load washer fabric softener is not working.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 113 Answers
I would take boiling water and pour it down the unit in case something hardened in the line. Next, if that doesn't work push a heavier type wire in as far as it will go to force an obstruction loose. If no obstruction you will need to call a repairman. Good luck.
Posted on Nov 23, 2014
localwonder
  • 6784 Answers
SOURCE: front load washer
HI. your model has a dispenser solenoid for the fabric softener dispenser on this unit. If the solenoids are out or malfunctioning, it will render the dispenser useless. i recommend checking the solenoids on the fabric softener dispenser for continuity. The resistance should be 1100+- 7%. replacing this blown solenoid will fix this issue. Remember. the dispenser valve will not function without a working solenoid.
please rate and god bless.
Posted on Mar 22, 2009
SOURCE: whirlpool washer fabric softener dispenser
The fabric softener dispenser in my Whirlpool washing machine is caked w/hair and detergent. I have tried to take it out by unscrewing it, but it won't come out. What's the secret? Please help!
Posted on Sep 20, 2009
57 varieties
  • 1653 Answers
SOURCE: My bosch nexxt washer will not drain the fabric
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Posted on Oct 23, 2009
beltronic205
  • 1456 Answers
SOURCE: fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Posted on Nov 25, 2009
SOURCE: kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Posted on Apr 18, 2010
Fabric softener leaking from bottom of washing machine
One possible cause.
Someone is pouring fabric softener in the washer's Bleach bezel.
Causing the bezel to become clogged and then overflow.
Apr 02, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Where do you put the fabric softner
Some of these models had the fabric softener cup in the top of the agitator but I don't believe this model does .You will have to do it the old fashion way and wait till the rinse cycle starts and open the lid an pour it in.. Or get one of those Downy fabric softener balls for dispensing they work great and you wont have to stand by the washer to try to time it right...Hope this helps GOOD LUCK
Sep 16, 2010 | Whirlpool LTE5243D Top Load Stacked...
Cleaning Fabric Softener Dispenser
it does come apart it is stwited in from the bottom up . but you can soak it in some hot water and shake it it will come clean after a bit
Jun 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The fabric softener is clogged with dried up fabric softener on my Whirpool Washer. How can I get it cleaned out?
You really cant take them apart without breaking the dispensers. Fabric softner is basically wax and fragrance. Add very hot water to the dispenser to melt the fabric softner. In the future, water down the fabric softner.
Feb 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Fabric softener is not transfering into the washer. It stays in the fabric softener compartment. What can I do?
isolate electricity supply,isolate water supply.take the top off the machine.find and locate pipe/hose for fabric softener from soap drawer to drum.remove and check for obstructions.this should solve the problem.
Nov 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer fabric softener dispenser cleaning
Sep 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Washer, Fabric Softener Dispenser
THIS IS AN EXPENSIVE FIX FOR A SMALL PROBLEM I RECOMMEND BUYING A "DOWNEY BALL" IF YOU MUST HAVE FAB SOFT
Aug 04, 2009 | Whirlpool WTW6400SW Top Load Washer
I have a Whirlpool Cabrio washer (WTW6400SW). It
try cleaning the dispencer first, it has a small syphon assembly in it whcih can get blocked with concentrated fabric softiner and sometimes powder.
Jul 30, 2009 | Whirlpool WTW6400SW Top Load Washer
My Whirlpool calypso top loading washer poured water from underneath, water everywhere, what do I do and how do I do it?? No codes showed up. Thanks for any info. Rose
Sounds like the seals & gaskets have failed. If you removed the wash plate trying to unjam the washer and did not also replace the gasket kit, you may have violated the integrity of the water tight seals. However, sometimes also the fabric softener dispenser especially, gets clogged and may overflow and leak if the tubes are clogged with coagulated fabric softener. As I am writing this, my washer's fabric softener dispenser is clogged and the method I use to clear it has not worked this time - a cup of boiling water to melt the congealed fabric softener. One has to open the top lid (method varies by Calypso model - Whirlpool or Kenmore) to get to the dispenser tubing and reservoir underneath to get things flowing again, and in fact I have a small water leak on the floor where the dispenser overflowed a bit. That you have a leak, if it happens to come from such a clog, at least gives you a sign that your dispenser solenoids are not malfunctioning, requiring replacement of one of the circuit boards.
Apr 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
437 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
