Question about Ovens
My clock is on but I don't have any controls on. Is there a fuse or is my control board out?
  • 960 Answers
  • If the clock is working, you know there is power to the cooker. Make sure its npt set to auto cook and set the correct day time on the clock.
Posted on Nov 24, 2014
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
I have lost all power to the ovens and clock..but the gas igniter still works
No make or model given so answer is general in nature-
Burner igniters are not normally controlled by the main electronics board that supplies signals to the clock and oven controls.
This may be caused by a blown fuse on that board, a failure of the board itself or the power supply that provides operating voltage.
Feb 03, 2015 | Ovens
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Jun 11, 2011 | Kenmore Ovens
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
Sparks from the thermostat control! - frigidaire oven
you may have blown the control board. or blown the ac main control fuse for you home wiring. this is in your fuse box cookers have there own fuse separate from other appliances.
Jun 13, 2017 | Ovens
No 7 &beeping
HI. This is the result of the Function key that is shorted or stuck.
This will require you to Replace touch pad, or if touch pad is part of the clock, replace the clock (ERC), or main control board.
Clock = Control board
ERC = Control board.
Dec 16, 2009 | DCS Ovens
My Kenmore 9114742592 Wall Oven does not work. The display is blank and the circuit breaker is not tripped. What can I check for?
HI, check the junction box for separated power cord wires. replace the junction point if the wires are separated and not connected to the oven properly. replace the cord as well in this case.
Now, if the power cord is ok and, the junction is connected properly, this will confirm that the control or, clock has failed. replace the clock or, oven control board in this case.
Jul 10, 2009 | Kenmore Ovens
LED display stopped working
Hi!!! your clock or control board has malfuction.You can get access from the back of the unit pull the unit out and look at the back remove the screws..Your control board clock board went bad..Good luck..
Jan 04, 2009 | Belling XOU252 Electric Single Oven
Electric surge turned off the clock,oven but the stove top works
The clock and display are leds, right. If you can remove the panel where the board is and gain access to the back of it, look for a fuse, similar to a car fuse. The elements are controlled by manual independent switches, that's why they are working. If there is no fuse, or its still good, look for a burnt wire of some sort back there, as you said a power surge went through it.
Feb 19, 2008 | Ovens
Ovens Logo
61 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
