Question about MTX Thunder 4500 T4510-04 Car Subwoofer
Will two mtx thunder 4500 12`s handle a keenwood kac 7252?
    Sergeant:
  • 228 Answers
Your speakers should be more than adequate for your amp.
Posted on Dec 01, 2014
4 Suggested Answers
pumpkinman
  • 1144 Answers
SOURCE: my friend sold me his subs today and one sub
They probally would, but i just found that sub for 51.00 im sure it would cost that and more to have.it fixed
Posted on Nov 09, 2009
  • 156 Answers
SOURCE: what is best way to wire 2 mtx thunder 4500's to a
I would hook up the subs in parallel set up. Lower the resistance causes the amp to create more power to the amp. Your amp can handle 2 ohm load so from my stand point it is best to set up this way. Here is the link that displays how to set up subs:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Posted on Feb 12, 2011
  • 8 Answers
SOURCE: My mtx ts5510 stopped working
Inspect speaker for loose wires/broken wires. Check inside box for loose connection. Blown fuse on amp. Ive literally pulled the wires out of the speaker. The little mesh ones from the terminal to the cone. Look for that. If you do find something broken or bad. remember you can call MTX and fix for a flat rate on most evrything they carry. Ive sent several amps there. normally around $100
Posted on Apr 02, 2011
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
How many watts will the 10 inch mtx thunder 4000 have
It should tell you on the back of the sub ,The continus watts it will handle, If not phone the place you got it from, Or some place that sells them,
Nov 28, 2012 | MTX Thunder 4500 T4510-04 Car Subwoofer
What is best way to wire 2 mtx thunder 4500's to a kenwood kac-7205? thanks! james
Feb 12, 2011 | MTX Thunder 4500 T4510-04 Car Subwoofer
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
I a looking to qire two 10 inch kicker comps what is the best way to get sound out of this set up in a sealed box and kac 7252 amp 1000 watt
check the ohms on the subs if its single 2 ohm make sure you dont bridge it avoid 1 ohm unless the amp is class d duel 2s make 4 or 1 depending on if you series on paralel them duel 4s make 2 ohms or 8 you want to make a duel 4ohm 2ohm and put one on each chanel email me for better exp.
Feb 05, 2010 | Kenwood KAC-7252 Car Audio Amplifier
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Jan 23, 2010 | MTX Thunder 81000D Car Audio Amplifier
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
Help
If it only does it when bridged, the ohm load may be too low.
Is it blowing the fuse on the amp or the one near the battery?
Jun 15, 2008 | Kenwood KAC-7252 Car Audio Amplifier
Power of amplifier
If the KAC-7252 is to be bridged, the operation mode switch on the top of the amp is set to mono. When switched to Mono, the signal from the left channel input only is used. Bridging creates 4 times as much power so the KAC-7252 delivers 170 Watts per channel so that 340 watts total so that value 340 is multiplied by 4 and that gives you 1360 watts of power. so it will drive them.
Aug 27, 2007 | Kenwood KAC-7252 Car Audio Amplifier
MTX Thunder 4500 T4510-04 Car Subwoofer Logo
79 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
