Question about Robinair 34750 R-134a 50 lb Empty Refillable Refrigerant Tank
How do u empty tank ?? I can't find how to get into it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 113 Answers
You shouldn't have to empty pan, the fan usually evaporates any water accumulation. I know of no water tank on a refrigerator. Hope this answered your question.
Posted on Nov 23, 2014
Full tank light keeps appearing when the tank is empty
Full tank light??
My fuel light comes on when tank is empty, are you sure you aren't misunderstanding it. Not heard of one to indicate when full, only empty.
Sep 11, 2015 | Cars & Trucks
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
I got a 2001 Chevy Venture and fuel gauge always stays on full
The problem is in the fuel sender unit in the tank. It sounds like the float part of the sender unit is binding when it's at the top (when tank is full) and hangs up there till it falls back down when tank is near empty. It will likely have to come out to be checked, fixed, or replaced. Good luck.
Apr 11, 2012 | Chevrolet Chevy Cars & Trucks
Fuel gauge reads past full all the time
when the tank is full the resistance is low so the power through the gage make is read full
as the tank empties , the resistance increases so the less current means the gauge reads less until empty there is little or no power , the gauge reads empty
simple check , turn the ignition off, no power , no gauge reading
Sep 09, 2017 | Chevrolet S 10 Cars & Trucks
Which gas tank empties first on a 2001 chevy suburban?
I'm not sure about a Suburban but I have a 2001 Chevrolet truck with two tanks and they empty simultaneously so when the gas gauge says empty that means both tanks are empty.
Apr 30, 2011 | 2001 Chevrolet Suburban
I have a 2000 mustang and my fuel guage works fine. But 7 gallons fills it up from empty. As I drive the guage travels from full to empty just like it should. I do not have any dents in my tank.
I do not think you have any dents in your tank, nor do I think its empty when the guage indicates that it is.
It is more then likely a fuel level sending unit which is located inside of the tank. They are not fun to replace, empty the gas, drop the tank, and then replace the sensor.
Mar 08, 2010 | 2000 Ford Mustang
1994 Dodge Dakota Gas Guage not working all the time
Sounds like the sending unit is bad in the tank.
Jul 04, 2009 | 1994 Dodge Dakota Club Cab
Emptying the powerbrush
Gently
press the Quick Release tabs on the Clean/Solution Tank
and slide the tank off of the unit.
Grab the Dirty/Collection Tank and pull to remove.
While at the sink, remove the Tank Cap by turning
approximately 1/4 turn counterclockwise and lift
out the cap.
Empty the tank. Rinse the Dirty/Collection tank with
warm water.
Replace cap and turn approximately 1/4 turn clockwise,
until snug.
Slide the Dirty/Collection Tank into the unit. Replace the
Clean/Solution Tank.
The tabs on the side is what locks the tank on, if they won't release the tank, then you may have to take apart to get it off and replace the tank.
Jan 30, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Hm3500
It's not a problem for the tanks to empty at an uneven rate...as long as the second one continues to supply water after the first one is empty. Yes, a slight tilt off of level could cause this. One way to test for this is to turn the entire unit around. If the floor is uneven, this might cause the other tank to empty first. You could also try placing a thin spacer (cardboard?) under a couple of the feet to change the level. Whichever tank is lowest should tend to empty last.
Jan 26, 2008 | Holmes Products Cool Mist HM3500...
Robinair 34750 R-134a 50 lb Empty Refillable Refrigerant Tank Logo
91 people viewed this question
Top Robinair Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Robinair Heating and Cooling Expert? Answer questions, earn points and help others
