Question about Kenwood Kac-7252 2-channel 1000watt Power Car Audio Amplifier
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
  • 3 Answers
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Posted on Dec 08, 2014
  • Planeta Tres
    Planeta Tres Dec 08, 2014
What is best way to wire 2 mtx thunder 4500's to a kenwood kac-7205? thanks! james
I would hook up the subs in parallel set up. Lower the resistance causes the amp to create more power to the amp. Your amp can handle 2 ohm load so from my stand point it is best to set up this way. Here is the link that displays how to set up subs:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Feb 12, 2011 | MTX Thunder 4500 T4510-04 Car Subwoofer
I have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Feb 28, 2010 | MTX Car Audio & Video
Car audio amplifer blowing fuses
why are you in stereo for subs? mono all the way.
Feb 21, 2010 | Kenwood KAC-7252 Car Audio Amplifier
Help!
You probably need to run 4 gauge wire if not already done so, and check the fuses on the amp, add the fuses together then buy the right fuse rating for the fuse connected under the hood
Sep 16, 2008 | Car Audio & Video
Help
If it only does it when bridged, the ohm load may be too low.
Is it blowing the fuse on the amp or the one near the battery?
Jun 15, 2008 | Kenwood KAC-7252 Car Audio Amplifier
4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Mar 08, 2008 | Car Audio & Video
MTX Thunder 8302 Car Audio Amplifier
could be bad mosfets or outputs, needs replace
Aug 05, 2007 | MTX Thunder 8302 Car Audio Amplifier
Keep poping the 40 amp fuse on the amps itself when the volume is up at all it seems
Your units drawing too much current. it could be a wireing problem, a speaker problem, or the amp has a problem. the correct way to troubleshoot this would first do or have the amp bench tested. Or you can remove all the speakers and wires and turn up the amp. If the fuse still pops,have the amp serviced. Good Luck
Aug 16, 2006 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood Kac-7252 2-channel 1000watt Power Car Audio Amplifier Logo
Top Kenwood Video Cameras Experts
Are you a Kenwood Video Camera Expert? Answer questions, earn points and help others
