Question about Hitachi 55VF820
I cant get my tv to stay on
It will go off an the temp light will go red
    New Friend:
  • 14 Answers
You probably need a new lamp. They cost around $30 to $40 online with a google search.
Posted on Nov 29, 2014
Auto coolant hot temp light comes on and temp gauge goes up more when idling at a light
If temp gauge is going into the red on a 3.4 engine it must be shut down or head damage can happen within minutes. I have a Monte Carlo that was overheating. I changed everything, thermostat, water pump, belt tensioner, radiator, all with no result. It would start out okay on a cold start but then I would come to a red light and the temp would creep up. Higher and higher until it neared the red zone. The heat would run cold. Most of the time, as soon as it was about to touch the red it would start to drop, the heat would blow hot again and all seemed okay but not for long. This would get worse and worse until the red hot light came on and I found myself on the side of the thruway. This problem is a blown head gasket. I had no other obvious signs, no white smoke from the exhaust, no oil in the antifreeze. I even changed the intake gaskets. Head gasket issues are common on the 3.4 liter engines.
Sep 09, 2012 | 2002 Chevrolet Impala
TV went off, and three lights come on (green "power", red "temp", and red "lamp")for just a second, in succession from left to right.
My television had two red lights flashing, one for Temp and the other for the lamp. I removed mythe lamp assembly and the bulb filament was burnt out. I order a new lamp and housing unit UX21517 and replaced it and now I have the red light flashing which is calling out the lamp again.
Oct 10, 2009 | Hitachi 50V720 Television
Temp light
well blue is OK when thermostat opens it should go off this means the car is at operating temp as long you do not have orange or red temp light should be OK hope this helps
Sep 18, 2009 | 2000 Volkswagen Beetle
Red warning light is on and f1 flashes were the temp shows 04gsxr
blinking red light means critical error check your oil if you have oil in the motor check the sensor on the oil pan! good luck! had the same problem wire was bear making contact at bottom near oil pan good luck!
Aug 29, 2009 | 2004 Suzuki GSX-R 600
Temp guage in red' dummie light on engine not hot
Sounds like a faulty sensor, if the actual temp is 195/215. The ICM is processing the information it receives from the sensor and performs accordingly. A complete diagnostic scan would be helpful in determining the proper repairs needed to correct the problem.
Good luck...i hope this helps, please rate me a fixya.
Jul 17, 2009 | 2001 Chrysler 300M
The red lights are blinking under lamp and temp.
did you try setting the lamp over the red light on the tv?
Jul 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Haier wine cooler
Haier BC112G service & user manual:
To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
Nov 25, 2007 | Haier BC112G Wine Cooler
Hitachi 55VF820 Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
