Question about KitchenAid 6000 HD STAND MIXER 6 qt BIG Super Capacity Countor Black Professional Large Refurbished
KitchenaidKsm6573CER1 the shear pin retaining fell out
The shear pin fell out
  • Ross Keen Nov 30, 2014
    Hi Angela , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Which shear pin where? The external planetary one?
  • 5 Answers
If you are referring to the pin that holds the stand-lift lever to the stand-lift mechanism, then you'll have to remove the Motor Housing, remove the motor and the three screws below it. Then you'll want to seperate the Column from the Base by removing the three screws at the bottom of the Base. You can then access the lift assembly and all you need to do is reassemble the lever and the plastic hitch (forgot the specific name) to the bar with the spring and nut on the bottom, then secure it in place with your shear pin. (The pin may have to be re-bent into shape with needle-nose pliers, and I also advise putting "Locktite" onto the threads of the six screw that are used to secure the base and column to the lower gearcase.)
I hope this helps!
Posted on Jan 14, 2015
Proline 600
This is a fairly easy fix but you need a new planetary, some new grease a new gasket and about an hour. The planetary for your machine is a recent design, that did not work. the planetary and the shaft has been milled with grooves and they are pressed together at the factory. The tolerance was deemed to be tight enough to keep the shaft and the planetary together during the life of the machine....but sadly this became a common problem. They have since fixed the problem in the new design. They went back to pins and retaining clips from pre 2006. Your fix is inexpensive and ther are several videos on the internet showing you step by step how to do it yourself. Hope this helps.
Sep 17, 2014 | KitchenAid ProLine 600 Stand Mixer
On my Kitchenaid Artisan mixer the 3" silver rod fell out the back. How do I slide back in?
I an sorry but the only Rod in the back of a K45SS is the pivot hinge pin that holds the motor head onto the base. if it fell out then the answer is simple. Turn the mixer upside down and wiggle the base while sliding the pin back in. Once the pin is back in place, there is a set screw in the middle of the shaft that you can see while you are replacing the pin, turn this back down with a flat head screwdriver untill it is firmly against the hinge pin. The culprit of the problem is this set screw. It came loose and allowed your hinge pin to vibrate out and then fall down or fall out as you said. once the set screw is back in place you will be fine. To avoid this problem in the future you might remove the screw entirely and put a drop of "Lock-Tight" on it that will help hold the setscrew in place for a very long time.
Dec 11, 2012 | KitchenAid K45SS Classic Stand Mixer
The power head nose that the mixing paddle snaps into fell off the mixer exposing the nose gear and ring gear inside the head. There is no apparent locking mechanism to hold the plate in place to the...
Hi BOBLUCAS820. From the symptoms you describe, I believe it is your Planetary/Agitator Shaft assembly that has fallen from the ‘head’ of your mixer. More than likely, the retaining pin or clip which secures the Agitator Shaft assembly to the Planetary has ‘sheared’ or broken, allowing the whole assembly to ‘fall’ out of the mixer head.
The good news is that this can be fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, feel adventurous, and your mixer is not under warranty. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the last file, KP2671XWH3.pdf (325.07 KB), of the 24 listed under Parts List (24) (check to see it this matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. I suspect your errant part is Illus No. 18, Retaining pin. There are two shown on page 4, and possibly Illus No. 25, Retaining Clip.
To gain access to these pieces will require removing the Transmission Housing (Illus No. 7), removing all the lubricating grease and removing the Illus No. 21, Bevel Gear. You’ll need a regular or Phillips screw driver, retaining clip pliers, and punch driver. When you remove the grease form the transmission cover and gears, be on the lookout for pieces of the Retaining Clip (Illus No. 25). The pieces of the sheared retaining pin should be found between the Bevel gear and the Worm Follower gear (Illus No. 19). With the transmission disassembled, you should be able to determine what parts need to be replaced and can order online.
You’ll need to replace the grease you removed with new grease. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as it may have ‘debris’ in it.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Dec 22, 2009 | KitchenAid KP2671 Professional 6 Series...
Hobart N-50 Mixer beater attachment spins but has no resistance
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Jun 04, 2009 | Hobart N50 Stand Mixer
Kenwood chef
I think your toothed belt is gone and have to be replaced.
Nov 29, 2007 | Food Mixers
Slips in all gears
you have no speed 1,2,3 right?first thing to do is drop the planetary (this is the bottom with the beater shaft)undo the bolt and it will drop down.you will see 1 gear,that gear should not spin without the shaft spinning too.if it does you have a sheared key on the gear.if you have access to the transmission check the worm gear attached to the motor it has a roll pin through it make sure its not sheared.then look at the top left gear assembly and check for sheared (broken)keys.clean up all the parts,if you dont you could miss something.let me know.
Aug 22, 2007 | Hobart D300-6036 Mixer
Hobart d300
http://www.food-equipment.com/parts_Hobart_mixers.htm About halfway down. Hope this helps :)
Aug 01, 2007 | Hobart D300 Stand Mixer
KitchenAid 6000 HD STAND MIXER 6 qt BIG Super Capacity Countor Black Professional Large Refurbished Logo
62 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
