Question about Kitchen Ranges
How do I replace the bake element of the upper oven of the kitchen aid kebc207kss02?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Here is a link to the element and there is also a video on that same page to show you how to replace the element. Whirlpool W10207400 Elmnt Brol AppliancePartsPros com
Posted on Nov 30, 2014
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Posted on Nov 10, 2007
  • 574 Answers
SOURCE: Replace oven baking element on Kitchen Aid model # KESC300BWH6
It is easy!! After you remove the two screws pull straight out and do so easily, there are two female spade connectors on the element that you'll have to remove. When removing don't pull on the wire itself,pull on the connector. You may have to use pliers.
Posted on Apr 05, 2010
  • 6 Answers
SOURCE: My kitchen aid electric convection oven (superba
You do have a lower element. On convection ovens they are usually covered. If you look in the bottom of you oven you should see it is elevated in a rectangular metal cover. You should be able to slide it forward and lift it away to expose bottom element.
If visual inspection shows no signs of burn out on it then you will have to test to see if it is getting power.
Can you tell if the top element is working for sure?
Posted on Sep 28, 2014
How do I replace the bake element of the upper oven of the kitchen aid kebc208kss02 double oven?
Take the info. Off the oven, make, model, etc., to parts store and get replacement. The part should come with instructions on replacement.
Nov 23, 2014 | Kitchen Ranges
Oven only lights from the bottom
BUTTOM ELEMENT CALLED "BAKE" ELEMENT, UPPER CALLED "BROIL" ELEMENT ---> SO IF YOU USE "BAKE" BUTTOM COMES ON; IF YOU USE "BROIL" , UPPER COMES ON :)
Apr 18, 2014 | Kitchen Ranges
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Apr 05, 2010 | KitchenAid KERA205PSS Electric Kitchen...
Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Feb 27, 2010 | Ovens
My lower and upper oven wont heat up
since either one is not working id say the clock assy is bad. we replace alot of btm oven baking elements ., but your clock is what sends power to the bake elements . so suspect clock. not a cheap repair
Sep 19, 2009 | Maytag MER6772 Gemini Electric Kitchen...
How to replace bake oven element on kitchen aid model KERA205pass5
This is a very simple repair. The following link explains how to replace the bake element:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
If you have not purchased a replacement element yet, the part number is 9755770. The cheapest place I could find the element was appliancepartspros.com for about $54.
NOTE: The element may be slightly mishapened during shipping. If you have to straighten the element to install, use care that you do not crack or break it.
If you have questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Sep 16, 2009 | KitchenAid KERA205PSS Electric Kitchen...
Bottom Baking element not working
dmiller58
If all your connections are solid then your controller is defective. Did you get any faults before changing the element? Does the broil (one at the top of the oven) work?
Post a response
Regards
Sep 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Aid superba (electric oven)
you will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
May 27, 2008 | GE JBP69 Electric Kitchen Range
Nov 10, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kitchen Ranges Logo
110 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
