Question about QuantumFX Quantum fx ant-105 digital hdtv rotating rotor remote outdoor tv antenna 35db
How to install ant105 ?
Installed after receiving some tine ago and did not work. Removed ,again trying. Needed the wire connection- directions to try again.Send to this address: geneusher65@yahoo.com. THANKS
    Master:
  • 423 Answers
How far are you from the TV transmitter?
Posted on Nov 23, 2014
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
Magicolor 3730DN toner not installed
I had something similar happen with a Magenta cartridge. My only option was to call Minolta. After hours on the phone they finally agreed to replace the faulty cartridge.
I suspect that from time to tame we receive a cartridge with a faulty chip.
Aug 21, 2012 | Konica Minolta magicolor 3730DN Color...
Added a 322 reciever to my lake house to be able to watch tv in 3rd room i had 2 standard recievers before. i installed a dish pro quad lnb & reciever had a separator w/it says dp plus 123254 tuner 2...
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
Jun 26, 2011 | DISH Network 322 DTV Receiver
New install only powers up and ejects momentarily then powers down modle kd-416 reset does not work
remove unit, read instructions line for line and find out what screws were installed incorrectly or which are needed.
Take the the harness and check each wire for proper connection. I always solder and heat shrink mine to a sub harness and then the stock wiring harness stays stock.
Try the stereo out again but do not install it all the way this time. hold it and try the cd. If it works, you probably had the chassis binding or something. Too much pressure somewhere.
Or it is a bad unit that needs to be returned.
Jan 04, 2011 | JVC AM FM CD DET FACE CAR STEREO
Can you tell me please: where do you insert cables from a cable box to a Yamaha RX-V2500 receiver I appreciate any help you can give. OK. The cables that were attached to my cable box were removed when the...
the coaxial cable from outside is connected to in (box), coaxial cable from out to digital in (RX) digital out to TV... (try scrolling through source to cable/ or component if this is HD) (all other devices can be connect to RX also like dvd using Red Yellow White cable or S-video w/red & white)
Mar 12, 2010 | Yamaha RX-V2500 Receiver
Trying to install my new home theatre
Are you sure the wire is not damaged somewhere? Are you sure that you are connecting the wire to the correct terminal on the receiver? Is the speaker OK?
To test all of this, try different combinations. With Right speaker working, disconnect the wire from speaker and connect it to the left speaker. If it doesn't work, then the left speaker is faulty.
Now disconnect the wire from receiver's right-front terminal and connect to left-front terminal. If it doesn't work, you are either connecting to wrong terminal or the terminal/receiver is faulty.
At last, try using the "left" wire to connect the rigth speaker to right terminal. If it doesn't work, the wire is faulty.
P.S. The +/- doesn't matter for testing, the sound should go either. It is just needed to have all speakers connected in the same polarity, because else the sound waves would eliminate themselves.
Oct 31, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Logitech cordless mouse is not working.
It could be the receiver is bad or the driver is not properly installed. Try to uninstall/reinstall the driver. Try also connecting the receiver into different USB ports of your computer
If same problem occurs, try installing the driver and connect the receiver into another computer to isolate the problem. You can uninstall the software after that.
If same thing happens, then contact the manufacturer to RMA the device.
Have a great day!
Sep 13, 2009 | Logitech Cordless Mouse
Logitech V220 cordless mouse won't work
The V220 is a quite nice rodent, my favorite. Check 3 things.
1) Is the battery facing the right way? Minus end goes in first. Green LED should turn on for a few seconds after the battery is installed.
2) Is the mouse ON? The switch under the mouse is supposed to turn on automatically when the receiver is removed. This does not always work.
3) Unplug the USB Receiver. Connect it to a different USB port. Run the Logitech Connect utility.
If the mouse still does not work, uninstall the Setpoint software and reboot. It is possible that the driver did not install correctly. After reboot, try Step 3 again.
Setpoint software is only needed if you want to use the wheel click or horizonal scroll features.
If all else fails, try installing your V220 on a different computer.
Mar 01, 2009 | Logitech Cordless Mouse
Driver from my ION VCR2 won't install - Windows XP
I called ION tech support 401-658-3743 and my problem was that I was connecting through a USB hub and they said I needed to connect directly to my computer and when I did..the hardware installed just fine.
Jan 01, 2009 | ION Audio VCR 2 PC USB VHS Video to...
Right rear speaker not working
Start by connecting it to one of the other outputs off the deck, say the left rear. If it still doesn't work, remove the speaker and connect it directly to the head unit. If it works, then it's the speaker wire, if it doesn't, it's the speaker.
If there are amplifiers installed, switch RCA cables left for right etc. and see if the problem moves with the cable switch, try the same with the speaker connections at the amp. This will narrow down whether it's the amp or the RCA cable etc.
Car audio problems can be handled by a process of elimination! Eliminate what it's not and you're pointed directly to what it is.
Oct 06, 2008 | Pioneer DEH-P7700MP CD Player
Open Questions:
See all QuantumFX Quantum fx ant-105 digital hdtv rotating Questions
QuantumFX Quantum fx ant-105 digital hdtv rotating rotor remote outdoor tv antenna 35db Logo
205 people viewed this question
Top QuantumFX Electronics - Others Experts
Are you a QuantumFX Electronics - Other Expert? Answer questions, earn points and help others
