Do you have plastic replacement shield for light bulb for GE Exhaust Hood - Model JV347 0XIAA - Serial GS867119C ?
Plastic shield over the 60 watt bulb is crumbling failing.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
I'm betting 60 watt is much higher than the wattage recommended generating way too much heat in the confined space under the plastic shield. There should be a sticker in the bulb compartment listing the maximum wattage recommended.
Posted on Nov 23, 2014
3 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: dimplex air heater
my guess is the power switch is shot.
Posted on Nov 04, 2007
  • 3315 Answers
SOURCE: the plastic wheels on my Firesense copper outdoor patio heater have crumbled. where can i find a sturdy replacement.
Rona, lowes , home hardware etc
Posted on Oct 07, 2012
Charmglow electric fireplace - fake flame does not work - serial #21704 DR 1839
If you are not getting any flame effects or the glowing ember bed, the bulbs (60 watt, small base chandelier) may be burner out.
To replace them, remove the plexiglass front and then the logs. The plastic glowing ember bed just lifts out, exposing the bulbs. Before replacing them, check to make sure they are not just loose in the holders.
Hope this helps you and thanks for choosing FixYa.
Sep 11, 2011 | Heating & Cooling
GE Deluxe 30 Range Hood ---can't find a 2 way bulb (Light/night light)???
The current Convertible Deluxe rangehood from GE doesn't support a two-way (light/night light bulb). You can use an incandescent light with an A15 type (60 watts or less) or a compact fluorescent (A17 or T2) with an ordinary screw base that draws no more than 13 watts. Some models can only use the incandescent light (RN328, JN327, JV338). The recommended compact fluorescents are available from www.gelighting.com (product codes: 85383 or 47486). Check you manual or products.geappliances.com for a pdf of your manual.
I wish that I could be of more help.
(the model of your range hood would be useful to get more information)
Jul 09, 2010 | GE Deluxe 30" Convertible Range Hood -...
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
How do I replace the headlight bulb on a 2000 Ford Escort ZX2?
² Coupe
² Sedan/wagon
2. Open the hood and disconnect the headlamp wiring socket from the
in-line connector. This will make it easier to change the bulb.
3. Remove the protective dust shield
from the housing by turning the
dust shield counterclockwise (when
viewed from the rear).
4. Release clip and disconnect the electrical connector from the bulb.
5. Remove the bulb retaining ring by
rotating it counterclockwise.
6. Without turning, remove the old
bulb from the lamp assembly by
pulling it straight back out of the
lamp assembly and replace.
7. Install the new bulb in lamp assembly by pushing straight in with the
bulb’s plastic base facing upward. Turn the bulb slightly to align the
grooves in the plastic base with the tabs in the lamp assembly.
8. Install the bulb retaining ring over the plastic base and lock the ring
by rotating it clockwise until it snaps into place.
9. Connect the electrical connector into the plastic base until it “snaps”.
10. Install the protective dust shield and lock the shield by rotating it
clockwise until it locks into position.
11. Connect the headlamp wiring socket to the in-line connector.
12. Turn the headlamps on and make sure they work properly. If the
headlamp was correctly aligned before you changed the bulb, you should
not need to align it again.
__________
Feb 03, 2010 | 2000 Ford Escort
Dont know how to take lightbulbs out of cookerhood
How do I change light bulb in my windcrest hood and what type does it take?
Mar 09, 2009 | Kitchen Ranges
How to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Jan 01, 2009 | GE PSW26SGRSS Side by Side Refrigerator
Light bulb replacementR
A fridge light bulb is usually a 40 watt appliance bulb with a screw base. It is heavy duty to last in the temperature. If it is not easily accesible to unscrew and replace, there may be plastic cover to unsnap.
Dec 27, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
Is the Advantium Mod: SCA1000HCC03 the same as the SCA1001SS?
They are indeed the same bulb, a 10W halogen. Care must be taken not to touch the lamp, as the oils from the skin will shorten its life. In many recent models, the oven must be removed from the wall (a two-person job due to safety concerns) and the cover must be removed. The manufacturers consider this a "technician-only" type job to lessen their liability. You can find helpful exploded view diagrams of both ovens and order the bulbs here: http://tinyurl.com/gv383
May 03, 2007 | GE Advantium SCA1001SS Convection /...
Kenmore 63694 light replacement
You can enter your full actual model number at either the GE or Sears parts site listed below and get exploded view diagrams and parts lists. On many newer ovens, they have to be removed from the wall so you can remove the outer cover to replace the bulbs on top of the chassis, in the rear, or near the hood openings. This is a safety measure to protect the customer from line voltage and high voltage. It's important to have clean and dry hands when you handle the new bulb, especially if it's a halogen type. The parts sites: http://www.geappliances.com/shop/prts/ http://www3.sears.com/
Dec 29, 2006 | Kenmore 63693 900 Watts Convection /...
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
