Question about Other TIM1213-8 TOSHIBA MICROWAVE POWER GaAs FET Gold
I used the steam function and set time to 10 mins but after less than 3 mins it sopped with the message: H55 I can't continue after that please help
That is the only information that's available Thank You
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Is my steam iron broke?
Get a new one. If it drew enough power to trip off your electricity then there is a problem that is not worth taking a chance on.
May 07, 2017 | Irons
I have sony h55 model camera. i insert the battery in inside of camera. but not working. Inside lame is lit. what's Problem?
Yes, if during initialization or other major function the power is interrupted, it can wipe out the internal logic for the camera. If that has happened, and the camera won't even power up, there is no known repair that can be performed other than through a licensed repair facility.
However, if your camera does power up and you damaged the flash card only, then it may be able to be low-level formatted, then re-formatted by your H55.
Feb 14, 2012 | Sony DSC-H55 Digital Camera
Need operating instructions
Try to go to the manufacturer's website and type the pc laptop's model # to get documentation for operating it.
Dec 12, 2011 | Computers & Internet
How do i get date stamp on the photos taken in DSC-H55
According to the user manual, your DSC-H55 doesn't have this function.
Jul 01, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
On my computer i have to push f1 to start it
first try to notice the message before the (press F1 to continue) message, it could be a bad component (memory, hard drive, etc...) or the time & date is not set correctly in the BIOS, this would help a LOT thank's...
Jun 25, 2011 | Dell Computers & Internet
How do I set the time date stamp
• Setting Date & Time Use the Date & Time function to set the date and time of your camera. This function is useful attaching date stamps on captured images. Your camera uses a 12-hour time format. 1. Press the navigation controls to adjust date and time value. By holding down the up arrow or down arrow keys, the numeric values change continuously. 2. Press OK to apply changes.
or you can get help from manual here
https://images-na.ssl-images-amazon.com/images/G/01/00/00/10/67/62/13/1067621330.pdf
at page 73
Good Luck
Jan 09, 2011 | Polaroid i1437 Digital Camera
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
STEAM FUNCTION STOPS WORKING
You need to replace the descaling resin. I have no idea where to find it, however.
Dec 06, 2009 | Irons
Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
May 22, 2007 | Black & Decker D2030 Iron
Other TIM1213-8 TOSHIBA MICROWAVE POWER GaAs FET Gold Logo
294 people viewed this question
Top Other Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Other Audio Player and Recorder Expert? Answer questions, earn points and help others
