Question about 1A Auto Parts 2001 Chevy Tracker 4 Door Manual Window Regulator Front Passenger Side
Tail lights and dash lights quit working
My dash lights and tail lights don't work have turn signals and head lights and brake lights
2 Suggested Answers
greywarriors
  • 167 Answers
SOURCE: 98 bonneville ssei... short created after attempting to install a aftermarket radio. dash lights tail lights do not work. head light switch no longer controls head lights. i unplug the radio and chang
Check and see if you have any relays that control the lights and all the other things that have stopped working. There will more than likely have something in common that has burned out and a relay burned out would cause that. Also if it has a light sentinel on it then the problem could be in that circuit. You need a good schematic and try to trace the problem. There is so many things that can cause problems in some of the wiring harnesses that they put on cars that it is just a trial and error without the exact schematic for it. I would almost bet that it is in the relays that controls the lights. I have a Blue wire with a Black stripe on it in my Ford Explorer that just has one end on it! LOL! I've been an Electronic Technician for 33 years and the only way I will work on car electronics is if it is mine. Hope this helps. I had about the same thing to happen on a 93 Cadillac and i was in the light sentinel relay in the left side of the trunk.
Col. Dana Gillespie
Posted on Mar 23, 2014
Testimonial: "ok, would u think maby i melted something together along the way in one of the wire harness? i hope not. i would hate to have to track that down, probably under the carpet or something. i replaced the light sentinel switch and it didnt seem to change anything, unless something was wrong with that one as well as i bought it from a junk yard but nothing looked like was wrong with the one i took out originally. what would the relay i need to check be called? i believe there's some up by the fire wall on the passenger side under the hood. would that sentinel relay also be in the same location as the cadillac u worked on? thankx for your help and advice i rely appreciate it."
Head/rear lights don't work.. But dash/hand warmers/brake light works
No Dash lights, tail lights or Marker lights But Headlights, brake ...
forum.ih8mud.com > Forums > Toyota Tech Forums > 80-Series Tech
Dec 6, 2014 - Now my taillights don't work but Brake lights, Turn signals are good. .... If all the fuses check good with a meter, then head upstream to the ...
Thread: Tail Lights won't work..Brakes,Blinkers,Reverse does ...
www.expeditionportal.com > ... > Toyota: FJ, Hilux, Tacoma, 4Runner
Jan 16, 2014 - 10 posts - ‎4 authors
My bulbs are fine, because the blinkers work, the brake lights work, and so do the reverse, but no tail lights ... I know that the "License Plate" lights are on the same fuse as the tail lights. ... However, I don't have a schematic, so I don't know if that's the case. ... Anywhere I roam where I lay my head is home.
Rear Lights May Not Work Due to Rear Light Socket Plate ...
repairpal.com > Problems > Oldsmobile > Silhouette
Tail lights don't work right. ... I would suggest if you can replace the heads of there bad then do all at once because of you ... Replaced bulbs but still don't work. ... What would make my rear brake lights not to work and also my traction part also.
Dash lights and running lights not working after installing ...
? 1:25
https://www.youtube.com/watch?v=SK36wPXo2EQ
Feb 11, 2014 - Uploaded by 4Runner Nation
I got the same problem with my 91 f150 but just the dash lights don't ... for my head lights n dashlights ...
turn signals, head lamps, tail lamps, auto dome li
Jan 13, 2016 | Saddlemen SNOWMOBILE REPLACEMENT SEAT...
How to fix my tail lights, my head lights work,brake light works and turn signals work, dash do too
Maybe a broken or lose wire. The turn signal and brake lights operate from one wire and the tail lights operate from a separate wire. It is possible that the tail light elements burned out of both bulbs. Pull the bulbs out and check them first.
Sep 26, 2014 | 1991 Toyota Land Cruiser
Dash and tail lights not workjng brake and turn signal on passanger side not working
The dash and tail lights are on two different circuits, and the brake and turn signals are on different circuits, so at least 4 circuits total.
I would start at the headlight switch and check for power on the first two issues.
Jan 18, 2014 | 1990 Buick Century
No tail lights or dash lights
If you have checked the fuses for those two circuits and they have power, the next step would be testing the headlight switch.
Feb 26, 2013 | 1999 Ford Expedition
I have 89 bronco 2 my brake lights turn signals both work my tail lights don't work have check fuse n blubs what might be the problem
The turn signals and brake lights use the same circuit and filament in the bulbs. The tail lights are on the other circuit which comes from the headlight switch.
Do you have power on the tail light fuse ?
Feb 25, 2013 | 1987 Ford Bronco II
My brake lights work but my tail lights and reverse lights don't work. Also my dash lights quit when I changed the switch for my headlights.
Check your fuses. I had the same problem with a 90 Honda civic. Dash lights went out, tail lights also went out. Replaced 1 fuse and all came back on.
Jan 11, 2013 | 1996 Dodge Neon
Interior dash and running lights dont work but my signal and brake lights work else works
Look at fuse #18, a 15 amp fuse, in the fuse block. This fuse powers both the tail lights and instrument cluster lights. Usually both of these light systems are powered by the same fuse so when your cluster isn't lit up you'll know right away that your tail lights aren't working as it's not safe to drive without tail lights. Your brake, turn, and head lamps are powered by different circuits. Hope this helps and good luck!
Aug 11, 2010 | 1997 Dodge Ram 1500 Club Cab
87 celica. tail lights do not work, but brake and others do
Check the tail light failure sensor. Located in the driver's side kick panel fuse box. ~Rick89GTS
Jan 06, 2010 | 1987 Toyota Celica
Dash and tail lights on a '91 Lincoln Town Car - quit working
From what you just said i dont belive the mechanic checked your fuses correctly.
Check your self to confirm, But if no avial i belive the controller for your lighting may be fried.
Feb 25, 2009 | 1991 Lincoln Town Car
1A Auto Parts 2001 Chevy Tracker 4 Door Manual Window Regulator Front Passenger Side Logo
80 people viewed this question
Top 1A Auto Parts Home Experts
Vernon Taylor
Robert Plante
Are you a 1A Auto Parts Home Expert? Answer questions, earn points and help others
