Question about Freezers
I have a haier 7 cubic chest freezer. It keeps shutting off. But if I tap the front dial on bottom right it turns back on and freeze again for a few days but then turns off again.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
The dial is more than likely the thermostat. If tapping on it brings it back on and then it cycles fine for a few days, the thermostat is needing to be replaced.
Posted on Nov 23, 2014
5 Suggested Answers
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
  • 20 Answers
SOURCE: Kelvinator chest freezer not freezing
SUM HUSBAND. call the handyman N-E-WAY
Posted on Jun 09, 2009
bobicehouse
  • 1524 Answers
SOURCE: Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Posted on Jul 30, 2010
SOURCE: i recently bought a norfrost chest freezer model
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
Posted on Feb 26, 2011
After placing my Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA in a horizontal or tilted position it doesn't want to freeze
If you have run it in a tilted position, the oil has migrated from the compressor to the evaporator. You need a technician to flush the oil back to the compressor. Only run equipment like this on a flat level surface. and always allow to stand a few hours after moving before switching on.
May 01, 2014 | Haier 7 cu. ft. / 198 liter Chest Freezer...
I need a replacement for the keys of my HAIER 7.3 FRREZER
what do the dial and buttons at the bottom to be set as.we dont have a manual?
Jan 12, 2013 | Haier 7.3 cu. ft. / 207 liter Chest...
I have a freezer that ices up about 12inches from the bottom model#HCMO5OEC and will not freeze the food
your freezer has a freon leak and the leak would need to be found, fixed and recharged for it to work again...
this would cost more then a new freezer...
heatman101
Aug 17, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Haier freezer and it wont freeze what should i do?
dear sir/madam
please make sure your freezer,s tempreture sensore is right location .if it,s alredy is in right location then reset the selectore swith to turn off and again turn possition.
hope answer the question.
thank you
Jul 03, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
How long does it take to cool before putting food into it
i would let it run for about an hour then stock it. this is what we recommend after servicing
Jun 05, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
I have Haier 5 cubic foot chest freezer, model # HCM050LA, that cools well with the green light on. When it is running it makes a very faint high pitched sound that seems to be coming from the top right...
Yes it does. It will have to be blowing inside so look in there. You will have to take the cover off.
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Nov 20, 2008 | Haier Freezers
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
74 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
