Question about Garden
Hi, which type of Loctite are you suppose to put on the crankpin of a trimmer/weedeater to get it to stay? Will the regular red or white threadlocker work fine? Thanks a lot, Josh
Crank Pin keeps coming out and hits the reed valve and read an answer saying to use Loctite. I just want to know which type to use? The glue, threadlocker, etc...?? Thanks a lot!
  • 5,568 Answers
If this problem recurs, I would remove the crank pin, put it on a vise or heavy steel block and carefully deform one en of the pin before pushing the virgin end back in place.
Posted on Nov 23, 2014
SOURCE: Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
Posted on May 30, 2009
  • 240 Answers
SOURCE: how do iremove trimmer head weedeater fl20
It depends on your model. You can visit the PIVOTRIM website and they show how to install their head on most units which includes how to take your old one off. Their website is http://www.pivotrim.com
Otherwise you need to look at your operators manual or call the manufacturer.
Posted on Jun 14, 2009
#1 Taper
  • 1040 Answers
SOURCE: Ryobi edger, trimmer, weedeater was working fine
If the trimmer has fire, (spark) Then:
check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 19, 2009
canbruce75
  • 1776 Answers
SOURCE: how to change string on weedeater trimmer electric
Check out the link that I am providing and see if the video helps you out. Sure hope so and best wishes.
http://www.youtube.com/watch?v=SuGfDNH6fXk
Posted on Aug 30, 2009
Dolfoff
  • 148 Answers
SOURCE: i am able to crank the trimmer but it does not
1) Change out the old fuel (not just adding fresh but pouring out the old and replacing it entirely) and check the engine oil.
2) Check muffler and/or spark arrestor screen for restrictions.
3) Clean and reinstall spark plug (check gap).
4) Replace inlet screen INSIDE the carb. (It is located directly under the inlet needle.)
Try each of these as needed.
Hope this helps!
Posted on Oct 01, 2009
PURCHASED A FAUCET LAVATORY 1 LEVER 4" 401509050051 FOR 85.99 AT RONA.i HAD A PLUMBER INSTALL USE IT THE PULL LEVER IT LOOSENS HAVE TO KEEP TIGHTING PASSED THEIR 90 DAY REFUND
Sadly... Brenda Salomone,
90 days is 90 days...
There USED to be "Life-time" warrantees on
Some of the BIG name AMERICAN manufacturers...
But that is water under the BRIDGE at this point...
(plus YOUR labor charges... ).
My best advice would be to take your handle
back down to the Plumbers supply and ask them to
recommend a "THREAD LOCK" compound like the
RED (or Blue: medium duty) products below... (Loctite).
Recommend...
only because Loctite is for METAL
(don't know ANYTHING about PLASTICS)
Red Heavy duty (for metal surfaces)
Amazon com Loctite 37421 271 Red Heavy Duty Threadlocker 6 milliliter Tube...
Hope this helps
Carnac the Magnificent
Jul 07, 2017 | Plumbing
I asked about screw from a frame to steering n how come its coming loose on its own this very dangerous n still haven't gotten answer on a Chrysler 2001
Go to an auto shop and buy a tube of Loctite. Undo the screw, put Loctite on the threads and retighten it. Fixed!
http://www.loctiteproducts.com/threadlockers.shtml
Jan 16, 2016 | Chrysler Cars & Trucks
Where did I get material data sheets from
There should be a phone # on package plus a website
Sep 10, 2014 | Loctite 272 Threadlocker, High Temp/High...
Torque for clutch and stator nuts
Clutch hub nut 70-80 ft-lbs 94.9-108.5 Nm
Left hand threads, apply several drops of LOCTITE
THREADLOCKER 262 (red) to last few threads.
Compensating sprocket nut 150-165 ft-lbs 203.4-223.7 Nm
Apply several drops of LOCTITE THREADLOCKER
Clean ALL old loctite from all threads on both nuts and shafts.
Jun 29, 2014 | 2003 Harley Davidson FXDWG Dyna Wide Glide
Crank bolt keeps undoing after ten or so miles
Try some Loctite on the threads:
The blue allows disassembly with common hand tools.
The red usually needs impact tools to undo.
Available at auto parts stores.
The crankshaft sprocket (for the primary chain) on Harley's use the red to secure the nut, as this is something you don't want coming loose on ya.
Apr 19, 2014 | 2006 Malaguti Phantom 50 Capirex
The head keeps falling off my weedeater brand weed eater
Add a split washer. Turn it tight enough to compress the split into a flat washer. The spring tension of the washer will hold it on. If not, you will need to add some Loctite.
Apr 17, 2014 | Homelite Mighty Lite Lawn Trimmer
Front panel on range came apart
Buy some Loctite threadlocker and put some on the screws that are coming loose. It is like a liquid plastic that prevents screws, bolts from coming loose. It stays rubbery so you can take the bolts out if you need to.
Mar 10, 2014 | Kenmore 9445 Range
How to adjust mix on WEEDEATER FEATHERLITE PLUS STRING TRIMMER Model FX 260
Red=High speed and White = Low speed
Clockwise closes needle, Counter clockwise opens needle. Set both needle to 1 1/2 turns open, then fine tune from there.
Apr 05, 2009 | Garden
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
