Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
The air conditoner will not turn on the remote works but the unit itself wont go on is there a fuse in it
    New Friend:
  • 4 Answers
The newer air conditioners have a button on the actual plug. It is a reset breaker switch. Try pushing the button on the plug while it is plugged in. (Assuming it has one)
Posted on Nov 23, 2014
My central air unit has stopped working. The outdoor fuses were blown and we replaced them but it still wont turn on
If the outdoor fuses blew, it is usually for a reason.. There may be an electrical failure in the unit itself which caused this. Most AC units have fuses in the indoor unit as well, but I would suggest getting a Tech to trace the reason the fuses blew in the first instance. Replacing blown fuses sometimes works but a lot of thime, more damge is caused to the unit. You usually know this when the unit goes "bang" and the fuses blow again when turned on...
Jun 16, 2011 | Amana Heating & Cooling
I have a GE Split-Type room air conditioner model number AA1AH24EWI.I used it last summer but now it wont turn on.Have changed the remotes batteries and checked if it is sending signal(looking through digi...
Check power is indoor. And also for long time no use cases, please remove batteries from remote and re fix it when it is on use. Keeping with old batteries for long time with no use will affect the remote. Please check with other remote. It doesn't mean your remote is good, if ultra light flashing thr' camera.
If with other remote, the unit does not start, It's receiving sensor problem. Then you have to repair or replace PCB. Helpful?
Jan 09, 2011 | GE Heating & Cooling
I have a conia YKR-F/06 air con & my remote wont work, can u turn it on from the unit itself?
Some units having manual button in unit itself. But you can't change temp setting or mode setting by that. It's advisable to get new remote and operate this. Thanks.
Dec 31, 2010 | Heating & Cooling
PORTABLE AIR CONDITONER MODEL#APEOIAJMI-DOES NOT
If you turned this unit on right away after you received it you may haved damaged the compressor. You should always let a rfrigeration or a/c unit sit in its up right position for atleast 12 hrs. before operating, so that pressures and oil can equalize inside the system, unplug the unit and check the wires at the compressor and make sure they are still connected, Good luck.
Mar 05, 2010 | Heating & Cooling
Panasonic air conditioner issues
does it freeze up? this could be a sign of low freon. does the fan turn on? if not the compressor will get hot and shut itself down on overload the fan can be easily replaced for around 100.00
Oct 08, 2009 | Panasonic CW-XC243HU Air Conditioner
LG Split unit turns itself off after a couple of seconds of opera
Check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Feb 15, 2009 | LG LSC121PMA Split System Air Conditioner
Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme mintex007@yahoo.com
i can send to u
Feb 07, 2008 | Heating & Cooling
Our AC won't come back on after i turned the power at the wall off and then on again. It was all working brilliantly till then and now i can't get a bit of life out of it. I can't even tell if any power is...
To OzAnday
If the light indicator of your unit have light with power "on", then there is a problem with the unit. May the fuse of your pcb is open or the pcb itself has a problem. You have to call a qualified technician to check.
To floscar
Reset the rest button of your remote control, but if it wont work may the remote itself has a problem or the receiver board.
Dec 31, 2007 | Fujitsu 24C1 Air Conditioner
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
458 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
