Question about Keurig 2.0 K550 Brewing System
How do I get my keurig off the hot water setting back to brew
I set to dispense hot water and am unable to be back to brew setting. I also am trying to use a reusable coffee filter, could that be the problem?
  • 6 Answers
Try inserting a K cup instead and see if it reads that and automatically returns to brew.
Posted on Feb 01, 2015
Why is my Keurig 2.0 not brewing full cups of coffee and unable to dispense only hot water?
I answered a previous question but as this has more information let me suggest you descale your system.
you can purchase a kit at Bed, Bath, and Beyond, or go online and learn how.
Apr 12, 2016 | Keurig K550 2 0 Brewer Black
Keurig B150 - continuous water dispensing
Their appears to be a scale build up inside the valve that dispenses the water when demanded. This is an electrical solenoid much like in fridge water dispensers but smaller. The scale is not letting the valve close completely after dispense. On a regular brewer running vinegar thru the machine a couple of cycles will usually dislodge the obstruction in the valve. If you can manually add water to the brewer, you should add the vinegar instead to clean the valve. Otherwise you may have to disassemble locate the valve and soak in descaler, or vinegar.
Jan 11, 2015 | Keurig Coffee Makers & Espresso Machines
My keurig is not dispensing water properly
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 28, 2011 | Keurig Coffee Makers & Espresso Machines
Keurig Platinum is clogged
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Mar 18, 2010 | Keurig Platinum B70 Coffee Maker
My keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Jan 02, 2010 | Keurig Special Edition B60 Coffee Maker
When I run water through the Keurig, it works fine, but the moment I put in a coffee, it balks, sniggers and refuses to brew. I think there must be something wrong with the perforation -- as though it...
Check the needle inside the k-cup reservoir to ensure it is clean and not clogged. You can completely remove the k-cup reservoir by pushing up from the bottom (where it normally dispenses into the cup) and it should pop out easily. Wash it out with hot water and check the needle for any debris. The manufacturer even recommends carefully inserting the tip of a small paper clip into the needles to push out any debris if needed. Then replace the k-cup reservoir by aligning the arrows and snapping it back into place. Lastly, brew a cup of just hot water on the largest brew size without a k-cup. This should further help clean out any debris or obstructions. Then try to brew a new k-cup as usual and see if the problem is corrected. Hope that helps...best of luck!
Dec 15, 2009 | Keurig B60 Coffee Maker
Keurig 2.0 K550 Brewing System Logo
85 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
