Changed batteries but still does not light
SOURCE: where do the batteries go
The batteries are located inside each leg of the flashlight. Just remove the end cap on each leg by twisting it off. Inside each leg is 3 AA batteries.
Good Luck!
Rich L.
SOURCE: how do i install batteries on stanley 95-112
I just found it! The batteries go into the tripod legs! genius
SOURCE: how do you change batteries
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
