I have a Casio fx-83wab. How do I calculate to the power of a fraction? So a number to the power of 1/3 for instance - I've tried the x-1 button with the fraction in brackets after it but that comes up as "syntax error"... Thanks!
  • 7,993 Answers
Use the general power key that is marked as [^], [Y^x] or [X^y]. Enclose the fractional exponent (1/3) in parentheses.
You can also look for a general root key, marked as [x Root]. To use this key, press the root index (3 for example), followed by [x Root] and then enter the argument. If the index of the root is even ( 2, 4, 6, ...) the argument (inside the root) must be a positive number.
Posted on Nov 24, 2014
2 Suggested Answers
  • 7993 Answers
SOURCE: casio fx-83wab
It can represented several ways. [^] , [Y to x] or [X to y].
Hope you find it.
Posted on Dec 06, 2009
Can a casio fx-115es reduce fractions
Yes. Simply enter the fraction and press =. If the calculator is in the MathIO mode it will display the fraction in its simplest form. If you're in the LineIO mode, press the S--D button to convert the decimal to fraction.
Aug 18, 2011 | Casio FX-115ES Scientific Calculator
I'm trying to do fractions on my casio fx-300MS S-V.P.A.M. can you help me
if you need to use fractions, look at the symbol the second button beneath the RED ALFA button.
Mar 31, 2011 | Casio FX-300MS Calculator
Trying to get calculator to display in scientific notation
Press the [SHIFT][MODE] to access the (SETUP) screen. -See the screen capture below. Press [7:Sci] to select the output display format to be Scientific.
You will then be prompted to key in a number between 0 and 9 to choose the number of decimal digits.
If you do not want fractions nor radicals set the default Input/Output format to LineIO.
To do so press [SHIFT][MODE][2:LineIO]. After that perform the steps given above to select Scientific format for the output.
Apr 16, 2010 | Casio fx-300ES Calculator
1 divided 5 =
Yeah? What do you want with it?Do we have to play good cop, bad cop to make you reveal what you want?
Could be just a fraction 1/5 or a decimal number 0.2
If you calculator gives you a fraction use the [S<->D] to convert it to a decimal number. If it gives you a decimal number, you can convert it to a fraction by pressing the [S<->D key.
Feb 14, 2010 | Casio FX-115ES Scientific Calculator
Problem for Casio FX-260 Calculator Changing fractions to decimals
To force a fraction to be displayed as a decimal number put a decimal mark at the end of the numerator OR the denominator. Fraction/decimal result is always decimal.
Nov 12, 2009 | Casio FX-260 Calculator
Help with my casio fx-115ES please??
Press [SHIFT][MODE] to open SetUp. Select [1:MathIO]
To convert a fraction to sa decimal and (maybe) convert back to fraction, use the [S<>D] key.
Jun 17, 2009 | Casio FX-115ES Scientific Calculator
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Fractional powers
use the "carrot" button, ^. Type in 4^.5 and you get 2. If you are going to use fractions, use the division bar and parenthesis and not the fraction key. Example 4^(1/2) = 2
Apr 27, 2008 | Casio FX-300MS Calculator
49 people viewed this question
jasbo
jasbo
