Question about Polaroid 0708090343 Main Board for TLX-04244B PV420TVM-A81H, B.ZRA53C8324
REMOVE BACK OF MY TV - Polaroid 0708090343 Main Board for TLX-04244B PV420TVM-A81H, B.ZRA53C8324
    Top Expert:
  • Polaroid Master
  • 73,698 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Posted on Nov 23, 2014
How to remove the Base from a Sharp LC 46D64U TV
No.
Stand or base on any model of TV should be removeable without taking the back panel. How to Remove Pedestal Stand from Your TV YouTube
Oct 31, 2016 | Sharp Televison & Video
How to I remove the back cover on a Toshiba 50L1350UC LED TV. I have removed all the screws as I have on dozens of other tv repairs, but can't seem to see how to remove this back cover. Thanks.
Toshiba TV Repair - Replacing 26AV5 Backlight Inverter ...
? 2:36
https://www.youtube.com/watch?v=ZoAn6ovLVXc
Apr 22, 2013 - Uploaded by ShopJimmy.com
There are various ways to eliminate static electricity, but the most common ... Return the back cover to its original position and secure all screws. .... Hi I am having problem with my TOSHIBA46TL963 TV 3D LED TV WITH NO ...
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
Free Fix For Toshiba 50" TV That Will Not Turn On. ... Removeall; Disconnect. Watch Queue. Queue ... p.s. could they put more screws in that back panel? .... Now the TV turns on, so does theLED backlight, but NO PICTURE!
Toshiba TV Repair - How to Replace 75021540 Main Board ...
? 2:38
https://www.youtube.com/watch?v=AUOAQR_raTA
Feb 28, 2013 - Uploaded by ShopJimmy.com
Toshiba TV Repair Main Board Replacement for LCD TV Fix No ... Unscrew and remove the back cover. ... LCD & LED TVRepair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD & LED TVs - Duration: 5:56.
Jan 17, 2016 | Toshiba Televison & Video
Red light green light on off all time tv will not turn on
ok if you have just replaced the bulb, first try taking out the bulb unit and putting it back in, if you have already tried this, then disconnect everything from the TV unplug it find a nice sturdy place where you can place the tv, at the back of the tv remove the lower back panel ONLY, the screws you need to remove will have an arrow pointing to them, once removed clean all built up dust, remove cooling fan and clean from dust , check it spins ok, remove silver plate in the middle and remove any built up dust, just to the right of the fan there is a sensor unsrew and remove check it is free from dust, on the left of the fan is a micro switch unplug but do not pull on wires to the far right you will see a retainer bar upright (silver) remove this, gentley pull all the circuit board assembly back it will not come out far, on the back circuit board unplug the top two plugs top left but DO NOT pull on wires pull the circuitry board forward just a fraction more, and behind it is yet another multi plug, pull out the one to the left and plug back in but clear any dust in mean time, gently put everything back and plug all that you have unpluged back in gently, put all bars and covers back on, and re-install equip to tv........ this is what i did to mine when i had this probem today after bulb replacement and it now works fine
Mar 16, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Remove stand on a Sony KV-35V75 television
I have not known of any Sony tube TV thay was attached to the stand in any way with exception of they had a cloth strap in the center in the back at the bottom of the TV that buckled into a pocket on the back of the TV, but nothing in the front, usually the TV just lifted straight up or slid back about 3 inches then lifted up, that is all I remember on that other than the TV is very heavy and maybe it is just stuck from being on the stand for a long time. Good luck!
Dec 27, 2009 | Sony KV-35V75 35" TV
How to install a SONY LAMP XL2400 into your TV
remove 2 screws from bottom back of tv(plillips) now carefully remove front cover.it unclips,sometimes you have to pry it off.take out screws from lamp cover,remove cover,take screws out of lamp, remove lamp.reverse process to put it back together.
Sep 19, 2009 | Televison & Video
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
How to remove stand from panasonic tv model no tx-32 l m d 70
Place tv on its BACK,with the screw holes underneath.Remove the four screws,remove stand,and turn tv over to rest on the sceen (on top of a towel)or some other cloth so as not to damage the screen,and replace screws.The reason for placing the tv on its back when taking out the screws,is that,unless you have a magnetic screwdriver when removing the screws the are difficult to remove as they are deeply recessed.
Apr 09, 2009 | Emerson RP6248 AM/FM/TV Radio
Remove back of TV
you have to take off the tires to get to the screws the lugnuts r on by clips then you can get the back off
Mar 13, 2009 | Disney DTD1363-CAR 13" TV/DVD
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Polaroid 0708090343 Main Board for TLX-04244B PV420TVM-A81H, B.ZRA53C8324 Logo
54 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
