Question about Liebherr C-1650 30" Built-In Bottom-Freezer Refrigerator With Ice Make
I have a Liebherr CS 1650 with a broken ice cube tray. The dealer can only find a repair kit, but I can't find any photos that show the actual ice cube tray. They want $139 for the kit. All I need is
I have a Liebherr CS 1650 with a broken ice cube tray. The dealer can only find a repair kit, but I can't find any photos that show the actual ice cube tray. They want $139 for the kit. All I need is the tray, but not for $139. Any suggestions?
    New Friend:
Posted on Nov 21, 2016
Why does ice cube maker have a yellow warning light on it and it's not making ice?
It is telling you something is wrong! Check your manual for what the warning light signifies and take appropriate action. Look under troubleshooting. Also check out support at web site for manufacturer.
Feb 12, 2016 | Liebherr Freezers
Replace ice tray
the complete ice maker will need to be removed from freezer because the thermistor comes on the new tray that you will replace.
Aug 30, 2014 | Liebherr Freezers
Why are the cubes not breaking apart when dumping from the tray?
It is over-filling and the cubes are fused together... If the fill is adjustable, lower it, but you may need a new water valve... Frigidaire Water Inlet Valve 242252702
Jul 31, 2014 | Frigidaire FFSC2323LS 22.6 Cu. Ft....
Ice tray became disconnected. How do you put it back
There is a release button on the side usually. You ae to push it in to realign try.
Oct 11, 2013 | Liebherr CS-1660 30" Freestanding Cabinet...
I HAVE ICE BUILDING UP UNDER LOWER DRAW OUR FREEZER IS A LIEBHERR 2966
I know this unit very well, this means the thermistor on the back panel has failed, the factory has an updated kit to fix this issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Liebherr Freezers
I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Freezers
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Doesn't make ice cubes. Water doesn't come in.
Hello it sounds like the timer on the ice maker may be the cause. If you open the freezer when the fan is off raise and lower the arm on the ice full shut off. listen for a faint clicking noise you wont hear if fan is going. If it does not click the problem is going to be in the actual switch. I have repaired several with this same problem with the switch but you would probably rather invest in a new ice maker or either buy some trays. As the ice makers can cost up to 200 dollars in some models. The only other thing to check is if the water line is bent or crimped off.
Jan 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice cube tray will not release ice cubes
Simply buy a replacement tray. The flexability of the old tray is gone and so no flex means cubes stay put. Aggrevating. A new flex tray is around 20 bucks and very easy to replace. 59688-1 is the part number.bca6e53.jpg
May 22, 2009 | Freezers
Liebherr C-1650 30" Built-In Bottom-Freezer Refrigerator With Ice Make Logo
301 people viewed this question
Top Liebherr Freezers Experts
richie46
ray gallant
Tom Chichester
Are you a Liebherr Freezer Expert? Answer questions, earn points and help others
