<!-- from fixya rte -->7 out of the 8 heads will not run - Office Equipment & Supplies
  • 24 Answers
DETAILS PLEASE!!!
The make and model would help us both out.......
Posted on Nov 23, 2014
Just replaced head gasket on a 2004 chevy impala.and it is running rough wont stay running
cam timing out ?
cant be much else stopping it running if it was running before
the head gaskets were replaced
were the heads referbed ... valves. faced ?
this link for any other owner needing advice
How To 2003 impala head gaskets 3400sfi
Nov 09, 2016 | Cars & Trucks
Cracked head causes
cracked heads come from running with out coolant, over heating, poor quality cast heads, running at excessive high speeds for long periods of time 9 Problem for hilux 2.6 diesel ) water hoses reducing flow, blocked water passages from badly installed head gaskets
Jul 21, 2016 | Cars & Trucks
We think that it stopped running due to no fuel. the engine ran rough ever since. Seems to be flooding to the point that fuel was getting into the oil in the sump. Running rough ever since.
Get a cylinder compression test done to check head gasket and to check head is not warped or cracked.
if head gasket or head problem = one cylinder may be affected causing fuel could get into the oil via a blown head gasket. if one cylinder not firing it would run rough.
Has the engine been over heated recently ?
May 06, 2016 | Cars & Trucks
Not printing black
Sounds like the print head needs alignment. If an "auto" alignment can't or won't be run, somewhere in the maintenance section of your printer driver software should be an operation for running a print head alignment and doing adjustments to get the printer aligned for clear printing. First you should check the maintenance program for "head cleaning" and run a couple of head cleaning cycles to see if a clogged head is the problem...
Jan 28, 2013 | Office Equipment & Supplies
Makita gas trimmer RBC221. engine runs fine but trimmer head does not turn.
would suggest that the cable that runs the head is broken or there is too much material wrapped around the head... remove the engine off the trimmer and check the cable that runs to the head....
Apr 07, 2011 | Makita EM4251 16" 4 - stroke String...
Blown head gasket?runs real bad, water out the exaust.
Well, it your running water out the exhaust, you can bet your heads are cracked. Its not just the head gasket. Check the salvage yards for a replacement head. It will save you alot.
Jan 14, 2011 | 1997 Jeep Cherokee Country
Despite repeated cleaning I cannot get the printer to work properly. I suspect that it may require a new print-head, Any recommendations as to where I might get one?
Before you throw out your print-head, try this to clear it:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
If no luck, then look for a replacement on at a Canon authorized seller or Ebay, Amazon or Alibaba, although I warn you that the print-head might cost as much as a new printer.
Dec 12, 2010 | Canon PIXMA MP540 All-In-One InkJet...
Despite cleaning ink head many times, the yellow cartridge seems blocked as colour not showing
You will have to clean the print head, not just the ink cartridges. Here's how to clear blocked print heads:
-if no luck, you may want to dip the print head into Isopropyl Alcohol overnight (can get it from chemist)
-if it still doesn't work, your print head may be clogged to the point where it needs repair or replacement, which will probably cost more than a new printer.
Nov 30, 2010 | Office Equipment & Supplies
WHAT IS THE COST OF REPAIR ON A HEAD GASKET FOR A 1997 SATURN SC? THANKS, JOE
1.9L SOHC - head gasket set which includes all gaskets needed to remove cylinder head with thermostat runs about $150.00. Head mechine ( check for cracks and milled ) $145.00. Labor time to remove and reinstall cylinder head 8.5 hrs X shops labor rate.
1.9L DOHC - head gasket set and thermostat runs about $210.00. Head mechine $175.00. Labor to remove and reinstall cylinder head 10.7 hrs X shop labor rate.
Labor times per Mitchell labor book, this is a guide all repair shops used.
Jan 12, 2010 | 1997 Saturn SC
One head freezes
You are short of refrigerant, the evaporators (heads) run in series and if you run short of refrigerant one of them will have reduced or no cooling depending on the amount of refrigerant left in the system. You should make sure that a leak in the system is found before just recharging the system or you will have to do it again in the near future.
Feb 17, 2009 | LG LSC091PMA Split System Air Conditioner
23 people viewed this question
k24674
