Question about HP PSC 1510 All-In-One InkJet Printer
Hp 1510 all-in-one
Msg: paper tray empty
no it's not
both ink cartridges have bee replaced
no paper jam visable
What next please
  • 306 Answers
Try uninstall and reinstall software.
Posted on Nov 11, 2007
What does the button on the the 1320n that has a triangle with an exclamation mark mean? The light next to it is blinking and we don't have a manual.
Attention light is blinking
This state can be reached in the following circumstances:
? Paper tray is empty
? Door open
? Paper jam
? Misfeed from tray
1. Verify that the print cartridge is present and that the print-cartridge door is closed correctly.
2. Verify that media is present in the input tray.
3. Clear any jams and perform paper-path functional checks.
4. Make sure that the interlocks are operating correctly.
To reset the printer after a jam, press the GO button.(Green Button)
Sep 21, 2011 | HP LaserJet 1320n Printer
Bottom Two Lights Flashing
Was printing recently and paper tray ran empty. Then cartridges jammed to the right side and bottom two lights flashed continuously, in spite of disconnecting power, restart, etc. Finally, in attempt to change ink cartridges, pushed down on housing for ink cartridges and heard a click. They were jammed in the far right position. Restarted printer and all worked fine. Not very techy, but it worked!
on Jul 28, 2008 | HP DeskJet 5550 InkJet Printer
Just install a new black ink cartridge on my hp psc 1510 all-in-one printer and receive the following error messages. Firstly (incorrect ink Cartridge on the right) after restarting the printer, I now...
HP are notorious for this sort of error reporting, not very helpful at all.
On your first point; Is the cartridge an original HP cartridge? If it is then remove it and re insert it pushing it home firmly. If not then either get a cartridge from a reputable clone supplier or use a genuine HP one.
Next point; Inspect the paper route minutely for debris and identify and clean the paper switch, which is a tiny micro-switch and can become jammed closed just with paper dust.
The Scrivener
Oct 12, 2017 | HP PSC 1510 All-In-One InkJet Printer
Paper jam
if its a **** shell unit pull out the ink cartridges, flip unt over and access it from the bottom( like a toaster) see if you can locate the paper on that side. if u can it should work fine again. then filip over and re insert your cartridges and print
Jul 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP1510 How to change out ink
there is pull down face just above the paper tray, put you finger in the slot and pull it down you'll see the ink cartridges on the right.
Jan 28, 2009 | HP PSC 1510 All-In-One InkJet Printer
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Oct 28, 2008 | HP 920 Plain Paper Fax
Blinking lite on a hp deskjet 970cxi printer
2 reasons.
1)paper jam internally. chk carefully.
2)paper sensor problem.
just moove a paper in tray &tell me green lite is glow/not?
Aug 11, 2008 | HP Office Equipment & Supplies
HP 6210 All-In-One
Open up the top and look into the cartridge/paper print area. Look in the corners, Sometimes little pieces of paper can still be stuck there. Once you are convinced that the paper and cartridge path is clear then...
Pull out the paper tray. Look inside the opening. If there is paper there then pull it out.
Take all of the paper out of the paper tray.
Turn it over (paper on top is now on the bottom of the tray)
Try it now.
Jun 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 1510 All-In-One InkJet Printer Logo
75 people viewed this question
Ben Johnson
