Question about kawasaki 2007 Jet Ski Ultra 250X
How do I stop gas from getting into the oil of my 2007 Kawasaki ultra 250X jet ski motor
Tried getting the motor to run hotter. Seemed to work for a while.
SOURCE: '94 kawasaki jet ski 750ss won't crank over.
if you subed it there is a good chance you may have sheered your timing key. its a preety easy fix. had it happen to me once
Posted on Jul 14, 2009
  • 3567 Answers
SOURCE: ISchematics for 89 kawsaki jet ski
Go to the site below where you can see a parts diagram for your specific WATERCRAFT. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part and/or the notation "Not Available" is in the description, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
If looking for an electrical schematic this site will not help. You will need a service manual for that.
Posted on Aug 21, 2009
ollie reece
  • 1167 Answers
SOURCE: how do you winterize a 2007 kawasaki ultra 250x
what do you mean by this buddy????
Posted on Oct 22, 2009
  • 330 Answers
SOURCE: i have a 1990 kawasaki jet ski that gets hot. the
Running too lean will cause overheating.also has getting hot been true from the time since or before rebuild.? Why was it re-built? To much sealent or wrong seals could cause high temp Also cooling system obstruction from intake needs to be eliminated as cause.
Posted on Apr 08, 2010
heimlich
  • 1978 Answers
SOURCE: 1995 kawasaki 750 jet ski
Check your plug color. You may be having a high speed mixture problem. Is your ski spitting water out the tiny hole on the side? You should try flushing the engine, you could have a motor full of sand if you beach the craft but do not wash the sand out of the back before starting. Also inspect the engine water tubes for cracks. From the hull to the motor and from the hull to the jet pump.
Posted on Sep 03, 2010
What is the gas-oil ratio mixture for a 1995 kawasaki jh750-a4 jet ski
50 to 1 that is 2.5 ounces to the gallon for pleasure riding
40 to 1 that is 3.2 ounces to the gallon for racing
May 09, 2015 | kawasaki 2010 Jet Ski Ultra 260X
Lost ignition keys, what do I do?
what a pickle you people put yourselves in . go see the dealer is only option you have
Mar 21, 2015 | kawasaki 2007 Jet Ski Ultra 250X
Jet ski troubleshooting
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Dec 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
Jet ski loses power when it gets hot
are all cylinders working ? carbs might need cleaning ! what compressions have you ? 100psi min !!
Nov 15, 2013 | Tempest Kawasaki Jet Ski 1100cc JT1100 STX...
2007 Kawasaki KX250F studders
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor contaminated, sticky float, plugged jets.
13. Carburetor has oil in the bowl due to excessive oil in pre-mix.
14. Carburetor vacuum diaphragm torn, cracked, not seated or installed improperly.
15. Multiple carburetors out of sync.
16. Fuel filter clogged.
17. Old or contaminated fuel.
18. Fuel tank vent system plugged or carb vent line closed off.
19. Gas cap diaphragm valve faulty.
20. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
21. Carburetor controls misadjusted.
22. Incorrect valve timing.
23. Valve springs floating, weak, or broken.
24. Damaged intake or exhaust valve.
25. Incompatible performance parts.
26. Control module may be in "LIMP" mode
27. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Just cleaned carbs now stuttering at low RPM fine at high RPM ninjette org
2007 Kawasaki 250X Ultra jet ski stutters and one fix
Kawasaki KX250F Service Manual
OEM Parts for Kawasaki
2007 Kawasaki KX250F Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 26, 2013 | 2007 kawasaki KX250F
What oil and how to you check it in a 93 kawsaki 750 jet ski, not engine oil the transmission oil
Your 750 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Jun 11, 2011 | Encore Software Kawasaki Jet Ski...
IF THE OIL TANK IS GONE CAN YOU RUN A JET SKI IF YOU MIX THE GAS AND OIL
Yes , the mix is the same as a standard out board motor. Pre-mix your gas oil mixture at a 50-1 ratio.
Feb 15, 2011 | Monkey Byte Development Kawasaki Jet Ski...
PlZ PLZ HELP kawasaki jet ski with fuel issues
Take your carburetor apart and clean it. There is moisture corrosion that is keeping the needle from moving. Be careful not alter the little teeter totter spring in any way.
May 15, 2010 | Encore Software Kawasaki Jet Ski...
Kawaski jetski 2001 130 ultra
it is a 3cylinder 2 stroke motor. Just use 2 stoke oil. Also when done riding hook up fresh water hose and flush. also spray motor down with wd-40. Just a nice thick coat after every ride. It does WONDERS>
Jul 28, 2008 | kawasaki PVS297OS
kawasaki 2007 Jet Ski Ultra 250X Logo
359 people viewed this question
Top kawasaki Boating Experts
Fabrice Wolters
terry stevens
ray gallant
Are you a kawasaki Boating Expert? Answer questions, earn points and help others
