Question about Health & Beauty
How would I go about bypassing the brake safety switch on a 3 wheeler mobility scooter
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
The purpose of the brake micro switch is for the controller to detect the scooter is in freewheel or in drive. To bypass it all you need to do is connect the 2 wires of the micro switch together.
Posted on Nov 23, 2014
SOURCE: Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
Posted on Nov 25, 2009
  • 177 Answers
SOURCE: batteries won't charge
Hi. Sounds like there is a faulty connection somewhere between the charger and the batteries. Are the batteries connected correctly. The charger uses the voltage level in the batteries to regulate itself. If there is a faulty connection, then the charge will not operate. Use a multi-meter to check if the batteries are connected correctly. There should be 24 to 26 volts across both batteries.
This fault can also be caused by a faulty charger socket. Check for any signs of melting or heat damage. There might also be a disconnected wire in the plug on the charger itself.Good luck. Neil.
Posted on May 29, 2010
SOURCE: I have a Rascal 245 Mobility Scooter which is 3
Obtaining a 4-wheeled front section is the best way to improve stability. The 3-wheeled front section on rascal 235 and 245 scooters easily detaches and interchanges with the 4-wheeled front sections(235 models are a little shorter (less legroom).
Posted on Oct 03, 2010
  • 692 Answers
SOURCE: Lost the key to my
Soutside how secure does the scooter have to be? Is it parked inside at night and does your partner leave it unattended for long? The reason I'm asking is because you can replace the keyed switch with a plain old on/off toggle switch for about 5 bucks. Just remoce the console unscrew the old keyed switch unplug the old switch from the wire harness and using the original connector splice the toggle swith to the connector tape with electrical tape and install in console. Check correct operation of the switch before you put it in the console. If it works ok install it and put the console back together and there you go a fix plus cheap too You can always call Invacare @ 1-800-333-6900 and order a new switch Hope this helps.
Posted on Oct 28, 2010
SOURCE: instruction manual for pride mobility sonic & celebraity scooter
Here is the link to all pride manuals for power mobility.All files are .pdf and searchable.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
Posted on Jan 04, 2012
Why wont my sports rider 3 wheeler go in reverse
hi David , can you please confirm that the reserve switch model on the handlebars or the headlight ?
Regards
Apr 14, 2016 | Ev Rider Powerful Mobility Sport Rider 20k...
My battery is charged, but my travel pro still won't run.
Is the brake lever in the correct position and not in freewheel mode !
Oct 02, 2014 | Pride Travel Pro 3-Wheel Mobility Scooter
I own a Pride Go Go four wheeled scooter. When scooter is turned on, even though batteries are fully charged, the scooter will not move. I have found that if i then switch it off and switch it from being...
Problem seems to be in the brake wiring or micro switch on the brake itself that is causing your problem check the brake and wiring to make sure you have good connections and check if you can see that the micro switch is working correctly. try leaving the switch on and moving the freewheel lever to see if it will reset without turning the switch off if it doesn't and you have to turn it on then off then there is a problem in the brake circuitry signal to the console and you will have to replace the brake/microswitch assembly. Hope this helps
Feb 28, 2011 | Pride Mobility Products Health & Beauty
I have a Rascal 245 Mobility Scooter which is 3 wheeled. How can I make it more stable than the little caster wheelers they use?
Sep 24, 2010 | Golden Technologies Golden CompanioN II -...
What are the advantages to having a 4 wheel knee walker versus a 3 wheel knee walker
the 4 wheelers are generally more stable, the three wheelers are more manouvrable
Sep 02, 2010 | Clarity Knee Walker Leg Scooter Ankle...
3 wheelers tip. Is there a stabilizing bar with 2
Hello, There is nothing available from the manufacterer or comercially for this type of scooter.
Some Scooters have Castor wheels underneath the edge of the footboards but they are usually have a higher ground clearence.
Jan 17, 2010 | Elite Pride Go Go Traveller 3 Wheel
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
234 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
