Question about Toys
We took our FENWAI pressure control model FW-10 apart and can't figure out how to get it back together... What do we do?
SOURCE: putting the halter back together
Finally I found the instructions for assembly of the halter.....here is the link
http://www.hasbro.com/common/instruct/Furreal_Friends_Butterscotch_Reattach_Halter.pdf
Posted on Dec 29, 2008
SOURCE: I took apart the straps
if you know the modle number you can look it up ..just google it or look on the car seats web site
Posted on May 08, 2011
  • 41 Answers
SOURCE: I am trying to find
You can use a generic replacement , I would check "Drillspot".
Don F
Posted on Sep 09, 2011
  • 33 Answers
SOURCE: searching for fenwai pressure control fw 10
If your compressor is a piston compressor, try cleaning the check valve which comes from the pressure switch to the tank (it has a little spring and a rubber/plastic valve inside)
Otherwise check to see if it is sucking air in properly, (whilst it is running, remove the air filter, and very quickly put your hand over the air intake to see if it is sucking whilst it is at 20 psi, if not, then it may be that the valves in the head maybe either broken or not seating properly
If it is not a piston compressor, then it maybe the MPV needing some attention
Hope that helps
Posted on Aug 30, 2012
  • 8 Answers
SOURCE: Zoo kids fishing pole. The string got all tangled
find the parts list on the internet first off. You just look and see what make and or type, modle, etc reel it is or was lol. But when you see the diagram of the parts that are used to build that reel. You should see how each part goes togeather and usealy has arrows that show what order each part goes in if thee are moer than one part that connect togeather. Remember just look up what reel you have and search for that reel with diagram. Or just search for the parts for it and it may have a diagram just pop up for you.
Posted on May 16, 2014
I took apart my sewing machine, Brother CE1100PRW, to clean, and "Error 1" would not go away, please help.
Brother says:
The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
An E1 message appears on the panel Brother
Apr 13, 2018 | Brother Sewing Machines
How do i put my sewing machine back together
Ugh!!! Just look for a parts diagram. That should help you figure out where pieces go.
Search for:
Make Model parts diagram
Dec 27, 2017 | Brother Sewing Machines
I took a Lefod Mod LF10-1H Pressure Control switch apart and I'm now looking for a diagram on how to put it back together.
You silly person you should not have taken it apart if you are not capable of doing the job
Dec 18, 2015 | Washing Machines
Searching for fenwai pressure control fw 10
Hope that helps
Aug 22, 2012 | Air Tools & Compressors
I have central pneumatic 21 gal. air compressor. The unloader valve is broke. The power switch is a fenwai model: fw-10. Where can I buy a new unloader valve?
If you should mean the switch that is pressure controlled that turn the compressor on and off- that is a fairly universal replacement piece, As is the power switch itself
If you needed that specific part, your best bet is Harbor Freight tools who owns the Central Pneumatic domain.
Feb 14, 2012 | Air Tools & Compressors
I took apart my PS3 Dual shock 3 controller and painted up. When i put everything back together and I tried turning on the PS#3 but it wouldn't turn on. When i was putting it back together it kept turning...
i would suggest reversing the steps you took and look for anything you missed or improperly placed components because you said it kept turning on so something got pressed together improperly and is giving you the negative results your having im sure you will figure it out
Dec 30, 2010 | Sony Dual Shock 3 Controller for...
Toys Logo
110 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
