Question about Health & Beauty
How would I go about bypassing a safety brake switch???? On a 3 wheel scooter
  • 3,368 Answers
That would be dangerious, do not do it.
Posted on Nov 27, 2014
3 Suggested Answers
SOURCE: Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
Posted on Nov 25, 2009
  • 26 Answers
SOURCE: brake not holding on incline
remove wheel then using screw driver
remove brake then replace and re screw
replace wheel
ted mobility centre penge 0208 676 0944
Posted on Apr 15, 2010
My celebrity 3 wheel scooter will not move. Batteres are charged.
There is probably a safety brake or lock on the wheels that may be engaged.
Jan 25, 2017 | Health & Beauty
Gogo ultra x runs for a few minutes on fresh charged batteries then a squealing noise starts and the brakes appear to create drag.
I would recommend to call electricians certified in your state and replace the entire circuit box new it is for safety and fire hazards
Oct 09, 2016 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
How would I go about bypassing the brake safety switch on a 3 wheeler mobility scooter
The purpose of the brake micro switch is for the controller to detect the scooter is in freewheel or in drive. To bypass it all you need to do is connect the 2 wires of the micro switch together.
Nov 22, 2014 | Health & Beauty
Go Go scooter wont engage gears
Try first without power to switch from freewheel to engaged. Its usually a small lever on the back by the wheels. If the scooter can be moved by hand its in freewheel. Switch the lever then move the scooter slightly til you hear it click in. They don't have brakes, They are supposed to live in gear and then are either moving or not. :) Hope this helps.
Oct 16, 2013 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
How to bypass key switch on pride legend side kick, lost key.
While this can be done I do not suggest it. The lock out system is then overridden and the scooter can become dangerous. Also the charger and other electronics will not function correctly. Replacing the switch can be easily done. Parts can be obtained through monsterscooter.com
Sep 07, 2013 | Pride Rally 3 Wheel Scooter
Mobility scooter keeps beeping
Go to the scooters website and download the service manual. It will tell you why it beeps and how to fix it. Bypassing the brake is unsafe and dangerous as the brake will not stop the scooter or hold it on an incline. That may have been your original problem (the brake)
May 10, 2017 | Cars & Trucks
T he unit will not start.Is there a safety switch.i do not have the manual .
Hi dma11955
Not much info to go by, but I'll try.
1. Make sure your batteries are fully charged, load test them if you are not sure.
2. Make sure the charger is not plugged into the wall. The scooter won't work.
3. Make sure the moter brake lever is in the locked position. The scooter won't move in free wheel.
4. If you don't have and indication of power most likely you have a bad controller. Can't check a bad controller, just have to replace it, they are costly, so try everthing else first.
5.Sometimes a bad brake or charger will give the same symptoms.
Good Luck
mimobility
May 02, 2011 | Health & Beauty
Brake not holding on incline
replace wheel
Mar 30, 2010 | Pride New Mobility Celebrity 3 wheel...
Parking brake safety bypass
If you have the old firmware then all you need to do is ground the parking brake wire
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 26, 2009 | Jensen VM9510 Car DVD Player
Health & Beauty Logo
63 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
