Question about Nokia E90 Cell Phone (Unlocked) - Black
Inner display backlight works, but it doesnt display anything, could this be the cable sockets problem? Thank you for help.
Ive already changed the flex cable, but without any positive result. It isnt physically damaged.
  • Jir Frebo
    Jir Frebo Nov 22, 2014
    Should i try connecting the internal display to the socket for the outer display?
  • Jir Frebo
    I should also mention, that when i pushed on the left side of the inner keyboard, it would sometimes help for a while, then it would go blank again.
    New Friend:
  • 11 Answers
If you look very closely (check in different lighting conditions), do you see anything on the outer screen at all? You probably won't be able to fix this yourself, but you might be able to determine if something is loose. Press a button on the phone, which would normally make the outer screen light up. Hold the phone firmly in one hand and smack it into your other, outstretched hand at different angles (i.e. smack the right side, left side, top, etc. several times). If the screen comes back on even for a moment, then something is just loose, and the repair shouldn't be costly. If you can see a faint image on the screen in some lighting condition, but smacking the phone doesn't help, then the problem is the backlight and you will probably need a new screen. If you can't see anything on the screen at all, and smacking doesn't help, then the problem is unknown
go to nokia care
Posted on Nov 26, 2014
Testimonial: "Thank you for your tips and detailed answer. I´ll try it as soon as possible."
Help please
it could be the heatsink on cpu
May 04, 2013 | Biostar MCP6P-M2 Motherboard - v6.0,...
Everything works fine but backlight on display is
Hi
Thank you for your query
Please try the following
1) Press the fn key + up arrow key
The above key combination increases the brightness on the screen
If this fails you have a faulty inverter in your laptop, this is relativley cheap to repair
If option1 doesnt work, please book the laptop into a reputable PC shop
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 18, 2010 | Gateway Solo 1450 Notebook
Inner display problem.
try a working LCD from another phone replace it if it doesnt work then change the flexi cable if not working as well wow ...........
Feb 04, 2010 | Motorola Mobility MOTORAZR maxx V6...
No pic no sound backlight is on found a site that a guy posted that could solder L2 on circut board now cANT FIND IT AGAIN
HI,,
IF UR FAMILIAR WITH ELECTRONICS,JUST TRY TO OPEN COVER AND REMOVE LCD DISPLAY SOCKET WITH NO.OF WIRES TOGETHER IS ONE MALE SOCKET,THEN KEEP IT AGAIN IN FEMALE DISPLAY SOCKET...IF IT DOESNT WORKS ,,APRROCH LCD TECH..
TNKS
RABBANEES
Nov 11, 2009 | Vizio VW32L 32 in. LCD HDTV
My Dual XDM7510 display quit working and I can't find out what is wrong. Everything else on the XDM7510 works. Help me please. It was working when I went in the store came back out and no display.
try checking the illumination light on the back of the radio if that doesnt work then try looking at the red ignitionswitch wire and make sure it is connected to the 12vt constant (the yellow wire)
Mar 10, 2009 | Dual Car Audio & Video
Cant change my sanyo 6650 mobiles incoming msg font
here i hope this helps you Display Settings
Changing the Text Greeting
The text greeting can be up to 15 characters and is displayed
on your phone’s screen in standby mode. You may choose to
keep the phone’s default greeting (“Sprint”), or you may enter
your own custom greeting.
To display or change your greeting:
1. Select > Settings > Display > Greeting > Custom.
2. Enter a custom greeting using your keypad and press .
(See “Entering Text”on page 39.) (To erase the existing
greeting one character at a time, press .
To erase the entire greeting, press and hold .)
Changing the BacklightTime Length
The backlight setting lets you select how long the display
screen and keypad remain backlit after any keypress is made.
To change the Main LCD or Sub LCD backlight setting:
1. Select > Settings > Display > Backlight.
2. Select Main LCDor Sub LCD.
3. Select Always On, Dim Only, or a preset length of time.
To change the Keypad backlight setting:
1. Select >Settings>Display>Backlight>Key.
2. Select Always Off or a preset length of time.
Note: Long backlight settings affect the battery’s talk and standby
times.
Note: The Always On setting returns to the previous value the next
time you turn on the phone.
Your Phone’s
Please rate this solution thanks...
Jan 30, 2009 | Sanyo Katana II (SCP-6650) Cellular Phone
How to fix e22 error
ive already change the carriage but it still doesnt work and it say's that it is in the mantenence progres (is not sinish) i cant print or scan !
can you halpe my?
Mar 11, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Phantom power
are you using the xlr connection socket. There should be 48 volts dc bwtween pins 2 aqnd 3 on your xlr connection. check for this and that the mic cable you are using is decent quality and has 3 internal conductors - some cheapies dont. the unit the require some repairs If there is no voltage on its input sockets.
Dec 09, 2007 | Tascam US-144 Sound Card
Need help my samsung s630
my lcd isnt broken ive taken hundrerds of pics but all of the sudden it doesnt display anything just black screen like its off!! WTF!! i didnt do anything it was fine then 5 minutes later it wasnt
Nov 14, 2007 | Samsung Digimax S630 Digital Camera
Display backlight problem
i have the same problem, i thought it completely blacked out, but i realized it was just the main backlight. i can see it if i hold a flashlight to it, but i tried everything to fix it, and ive had no luck.
Sep 21, 2007 | LG VX8300 Cellular Phone
Nokia E90 Cell Phone (Unlocked) - Black Logo
57 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
