Question about Nextbook Tablets & eReaders
My next book tablet won't rotate back to its right place, how do I get it back to normal?
I've tried to turn it on and off but it doesn't help
    Problem Solver:
  • 18 Answers
I'm assuming that the Nextbook uses an android OS for this answer. On the drop down menu that appears when you "pull down" the top right corner of the screen there should be a "rotation lock" button if it's on then turn it off, if it is off then there may be something wrong with the position sensor in the tablet.
Posted on Nov 22, 2014
I dropped my tablet and now everything is backwards words,screen,everything help
Hello! you might need to calibrate your tablet`s sensor, if that doesn`t work please turn off the auto rotation on your tablet, and then reboot your tablet. if that doesn`t work, please do a factory reset on your tablet by pressing power button + volume down, your tablet will go into recovery mode and look for factory reset.
Jul 29, 2015 | Tablets & eReaders
I've did hard reset on my next book it didn't work its froze on next book now that's after trying to update it also under next book it says powered by android now it didn&#
Look on back of the tablet and see if there is tiny tiny tiny little hole at the bottom that has the word rest by it. Youwill have to find a paper clip or a needle to stick in there and reset it.
After you get it unfrozen, do the hard reset again but be sure to keep holding the buttons until you get the reset menu.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
Nov 24, 2014 | Tablets & eReaders
NEXT BOOK WILL NOT CHARGE
there are most likely two things that are wrong with your tablet, 1. your battery is worn out or your charger/chargers might be worn out.Try plugging your tablets charger back in while its off and then turn it on. If that doesnt work then try the pinhole reset button while the charger is plugged in. Since your charger might be faulty have a professional check for shorts in the charger. if none of these work consider replacing the battery, the charger, or the tablet itsself. if this doesnt help you i apologize for wasting your time with answers that are incorrect or answers that you may have tried before.
Jul 04, 2014 | Nextbook Premium 8 Se Android
Allwinner A20 dual core android tab screen want rotate
Allwinner A20 is a name of a processor, so I'm not sure what tablet are you using.
There is an option to block rotation, for example if you want to read an e-book while laying on your back. Go to settings and try to find an option to unlock rotation.
Also, some tablets have a hardware (physical) switch on the side that locks rotation.
Jan 17, 2014 | Samsung Galaxy Tab Tablet PC
Nextbook problems
Just reset the settings and it should work after the device is reset. This does not wipe out data just the settings.
Nov 05, 2013 | Tablets & eReaders
Ipad screen not rotating
Hit home button 2 times then slide ur finger copper and click the cerved arrows
May 18, 2013 | Apple iPad (16 GB) WiFi Tablet PC
My pandigital ereader won't connect to wifi all of the sudden. I've tried everything. The manual said to reset, and now it's dead. Can't get it to turn on. Any suggestions?
I rare case,the wifi module can disconnect for it socket.
It's usually cause by mishandling the unit.
If it's under warranty then you should send it in for repair.
====== The DIY method is to power off the unit.
Place a large soft towel on a table.
Place the display face down.
Apply GENTLY pressure (side to side and top to bottom) on the back of the unit.
PLEASE apply pressure gently!!!!!!!!!
With some luck,you will press the wifi card back into its socket.
Sep 11, 2011 | PANDIGITAL 7270FW Tablet
My monitor display has rotated itself 90 degrees counterclockwise and I do not know how to return it to it's normal position. What do I do to return it to it's normal "Landscape" position?? I have a...
on the front of the toughbook there are 4 small buttons, the 3rd from the left which has a right angle symbol with a double headed arrow in it rotates the screen 90 degrees each time you press it. this is probably how you got it like that in the first place.
Aug 05, 2009 | Panasonic Toughbook-19 Tablet PC
Tablets & eReaders Logo
168 people viewed this question
Top Nextbook Tablets & eReaders Experts
D. E. Hev
Tom
Dustin
Dustin
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
