Question about Munchkin Inc Munchkin MC80 Contender High Efficiency Modulating Wall Mount Gas
I purchased a Munchkin Contender boiler wall unit in 2007. It's been serviced maybe once. It is throwing out an F13 error code which pertains to a low-speed fan. It should still be under warranty,
I purchased a Munchkin Contender boiler wall unit in 2007. It's been serviced maybe once. It is throwing out an F13 error code which pertains to a low-speed fan. It should still be under warranty, but need to have it serviced. Is there a chance that it can right itself by just resetting the unit or is it likely thta the fan has to be replaced? Is that covered under a warranty? I live in Elgin, IL and need a reputable serviceman that understands these units. Can you help?
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
Error code F13 showing on whirlpool ghw9300pw2, please help
Controller fails to detect door lock triac correctly This error code is displayed if the main control unit fails to detect the door lock triac correctly. Also, if the controller cannot unlock the door after 240 seconds after the cycle is completed then this error will be shown.
If displayed switch the washing machine off completely, recommend disconnecting it from the mains supply for a few seconds. Switch it back on and the controller will attempt to unlock the door once more but, if it fails to do so in the same 240 seconds the error code will be displayed once more.
  • Check all wiring and connectors between the main controller and the door lock
  • Check main control unit, probably requires to be replaced
Mar 09, 2015 | Whirlpool Washing Machines
F13 and F11 codes pop up
F13 is
Dispenser Circuit Error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
i snagged this answer from another site
i think its a worn bit of plastic
as it becomes britten when not always wet
much like a boat out of water
Mar 05, 2015 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Can you reset the control board or fan on the boiler
Turn power off on boiler would reset it what code are you getting?
Nov 12, 2014 | Trane Munchkin High Efficiency Gas Boiler...
Our munchkin boiler is reading code F10, can you tell us what that means
The F10 error code on a Munchkin Boiler is flame sense. Sometimes removing the flame rectifier probe and cleaning it resolves this issue. If this doesn't work, you should call in a certified Munchkin tech. I have heard that realignment of the front case has to be done so the ground path is completed for the rectifier to work properly. This must be done by a pro, however.
Feb 17, 2013 | Water Heaters
Meaning of fault code F13 on Frigidaire range #cfef372es1 ?
Hello, welcome to FixYa.
I understand you have the Frigidaire CFEF372ES1 range, correct ? I also understand based on your post you're getting the F13 error message, correct ?
This range is built by Frigidaire as you know and a
ccording to their service manual, here's what it is and what you can do
...I will also add, **Fault codes are not a foolproof system. Never assume that a part has failed based on a displayed fault code. **
...If you pull/slide the unit away from the wall and unplug it or turn the house breaker off for 30 seconds to a minute the control should reset. That should do it...unless the EOC (electronic oven control) has failed.
Let me know how you make out and if you need anything further I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Oct 27, 2011 | Kitchen Ranges
My AWOE8748 had a fault code F13. It has now switched itself completely off.
F13 indicates "Dispenser Circuit Error" in your washer.If the dispenser motor is not able to be driven to it's proper position this error code appears.Check mechanical linkage from dispenser motor to the top of the dispenser. The wire harness connections to the dispenser motor and Central Control Unit (CCU) would have been faulty so check for those.Also do a final check on dispenser motor.
Thank you !!
Jun 20, 2010 | Whirlpool AWOE8748 Front Load Washer
Munchkin Inc Munchkin MC80 Contender High Efficiency Modulating Wall Mount Gas Logo
534 people viewed this question
Top Munchkin Inc Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Munchkin Inc Office Equipment and Supply Expert? Answer questions, earn points and help others
