I bought a sound bar and couldn't wait to set it up but didn't realise the connections were wrong I got the red and white cables to connect to tv but my TV only has a digital audio out(optical) connection my problem.is I don't know what to look for to fix this I have looked but get confused please help me.
    Problem Solver:
  • 11 Answers
You should probably return the sound bar and get one with an optical input. Otherwise you can't connect it to your TV.
Posted on Nov 23, 2014
Just purchased a Panasonic sound bar and Samsung tv. The sound bar is hissing at low vol from one end. Should I return to the shop or is there a setting issue?
I would check your cable connections. If you are using an analog Red & White connection flip the red and white connections and see if the hissing sound changes to the other end of the sound bar. If it does then try new cables.
If you are using a 3.5 mm Stereo headphone plug then try a new cable and see if the hissing vanishes.
If the hissing doesn't change then take the soundbar back it is likely a defect in the internal wiring., either bad grounding or a short in the wiring.
Jan 14, 2017 | Samsung Televison & Video
Why is there no sound coming out of my goodmans 50w sound bar?
No. Red and white are left and right stereo sound. Yellow is for video. Do you have power to the sound bar? Are those red and white cables connected to audio OUTPUT on the TV? If they are connected to the audio INPUT to the TV, it won't work. You may need to connect the cable to a 'phones' jack on the TV. Can you connect the sound bar to another source (like an iPod or CD player)? That will test the sound bar itself.
Oct 18, 2014 | Televison & Video
Just purchased a Goodman 50 w sound bar connected to AUX on tv and sound bar clicked AUX on remote white light shows no sound just a loud buzz
To the best of my understanding an Aux port is usually an input port. So you might be sticking the sound bar terminals into the wrong connector in TV. The audio signal from the TV is meant to go into the Aux In port of the sound bar. Usually this will mean a pair of RCA cables (white and red) from TV out to Aux In. If you have done the right things then maybe check if soundbar is not in mute. Try some other source as well. Like connecting an iPhone or ipod stereo out to the Line In port in soundbar and selecting LineIn mode.
see page 7 in the soundbar manual. It is hard to know what TV connection you are using. Is it selected on the TV settings? http://www.goodmans.co.uk/support/downloads/user-guides/GDSB02BT20-ib.pdf
Sep 08, 2014 | Televison & Video
LG sound bar don't work on LG tv
Need models of TV and soundbar to be more specific.
Generic help: Not plugged in correctly (you connected to the TVs red and white sockets without realising that they are a "signal in" and not a "signal out" type socket. Incompatible (i.e. a soundbar that uses ARC but the TV doesn't have it). Wrong TV settings - You're connected to the headphone jack but you didn't bother reading the manual that tells you there's a separate control for audio out via that jack and it's buried in the menus. The list goes on.....
Read the manuals, and don't just guess where things plug in. That's always a good start.
Sep 07, 2014 | Televison & Video
I have a proscan with no sound so I brought a
You hooked up the sound bar to the cable box red & white sockets, right. Now you have the soundbar hooked up to the TV red and white sockets. Did you notice any difference with the labeling on the two sets of sockets? The cable box sockets were labeled "Audio Out", but the TV sockets are labeled "Audio In"
AV signals are directional. Any socket labeled "Out" will give a signal from it for connecting to another device e.g. the connection from the cable box to the soundbar.
Any socket labeled "In" is designed to accept a signal from something else, but it won't give a signal out. So you can't connect the TV's Audio In socket to the soundbar's Audio In socket because both expect a signal from something else and neither supply a signal out.
Check the back of the Proscan TV. Is there a socket labeled Audio Out? If so, use that.
Sep 03, 2014 | Televison & Video
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
Jun 10, 2011 | Sansui HDLCD-1900 19 in. LCD Television
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
I want to hook up a higth def. cable box to asoround sound jvcTH-M505 with no hdmi,( the cable box does have it )and a samsung 46 in series 6 model 610 lcd. I can get soround sound from the movies from the...
There are a couple of different ways you can do this but this is the easiest.
Items needed - One set of RCA audio cables (Red/White)
1) On the back of your TV there should be RCA plugs marked as "Audio Out". Connect the RCA cable to these connections Red cable to Red connector and White cable to White connector.
2) Locate on the back of the surround sound system the connections marked "Audio in (VCR)". Connect the other end of the RCA cable to this connection Red cable to Red Connector and White cable to White connector.
Now to get the sound to play press the "VCR" button on the surround remote and you should get the cable box sound on the surround system.
Good Luck.....
Jan 19, 2010 | JVC TH-M505 System
Ps3a
I have had this problem once before and it was because my sound output was was set to the (yellow white red) and so what you have to do is go to Sound Settings then go to Audio Output Settings then what your going to choose is HDMI then it will ask for what method and just select Automatic, then you should be able to here sound threw your tv.
Oct 13, 2008 | Sony Playstation 3 (PS3) Console
81 people viewed this question
 Grubhead
Grubhead
