Question about Bose Audio Players & Recorders
My Bose Wave Radio CD Player (top load) AWRC1P won't play CDs, it doesn't even spin.
I already replaced the CD laser but no go. Either the motor that spins the discs is damaged or it's not getting power?
hawkwatcher
  • 67 Answers
SOURCE: Bose Wave Radio/CD Model AWRC1P
Yes There is a pigtail fuse in unit. It solders to main board. In order to replace you have to pull main p.c.b to get access to bottom of board.
Posted on Jan 18, 2008
  • 77 Answers
SOURCE: CD Player doesn't work; says "disc"
i would say that your lense is dirty and yes cleaning it might help
Posted on Feb 11, 2008
  • 48 Answers
SOURCE: I have a Bose Wave Radio with CD Player - its broken
can you send a photo ?
Posted on Mar 11, 2008
SOURCE: Bose Wave Radio w/single CD player on top
My Bose Wave Radio/CD developed this problem about a year ago. I don't use the CD player much and kept the unit clean. The disc spins but, the system does not read it. Cleaning the lens with cotton did not help.
Read that Bose charges $75 to fix this problem.
Posted on Sep 24, 2008
  • 20 Answers
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Posted on Dec 31, 2008
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
Bose wave awrc-1g cd player spins but does not play.
You have done what i would have suggested, the Bose Wave unit will need to back to Bose for service, and there is a good chance they will need to replace the laser pickup assembly and cost should be considered even thoe it is top of the line.
Apr 02, 2012 | Bose Wave radio/CD remote control -...
CD player on Bose radio started making a click sound
did you clean the laser inside? that a thing I would do first
after that mail us again
Feb 10, 2010 | Bose Wave Radio
CD does not engage to play/ on/off button does not work on radio
I hope it is still under warranty and can be replaced, Bose products are littered with problems.
Pool loading of the CD can be a simple lens cleaning or a defective laser/transport.
First step is to unplug for 10 minutes then replug.
Failing that find the nearest service centre.
Hope this helps!
Cheers,
Jan 22, 2010 | Bose Wave Radio
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
The cd player is not reading the discs. The read out flashes and blinks but it does not read the music off the disc.
Try removing the cover and clean glass laser eye lens with rubbing alcohol and cotton swab. If cleaning doesn't work, then laser lens circuit will need to be tested and replaced. You can use an ohmmeter to test the capacitors and circuit.
Nov 13, 2009 | Bose Wave Radio
CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Jun 28, 2009 | Bose Wave radio/CD remote control -...
Jun 19, 2008 | Bose & Wave& Music System
150 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
